21st Century Truck
Martin
Yeah, every 14-50R sold meets UL498. There may be imported exceptions sold on Amazon. All we can do is look at the history of which have been failing and which have not. And these new “EV” receptacles are too new to have accumulated any meaningful history. Time will tell.
Hubbell receptacles rule, in my book.
mrau
23 Lariat⚡ER
According to Leviton site the EV rated plug are for both the higher amps and the high frequency of insertions. Still made in China.
I agree, Hubbell and Bryant are some of the best.
https://leviton.com/products/1450r
Scorpio3d
SS/IBA car wash owner
I checked every terminal, lug, and breaker with my FLIR thermal camera.
That is cool. I didn’t think about doing that. I will have to get mine out!
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Impressive.
Mewonders whether this "EV rated" label is meant for long continuous loads (EV charging) vice shorter intermittent loads (electric compressor motors, dryers, etc.).
It's a stove outlet so I would hope it's capable of running a stove for hours.
Edit: after reviewing the specs from leviton, the 4x cost of the "EV" outlet is merely for the promise of handling repeated insertions. Their ev outlet also has a slightly poorer fire rating.
You'd have to do a lot of insertions to wear out the regular $13 outlet. The cheap $6 outlet I wouldn't recommend but you could buy 10 of them instead of the $60 "EV" outlet.
This is marketed to homeowners, how many insertions is the average home owner doing?
stickyfingers
Sam
Toronto
Speedy recovery pal. That install is pristine.
FreshDaddyE
Raleigh
2023 F150 Lightning
I'm always humbled when I see you guys (and others) doing this type of thing yourselves. I've changed a few receptacles in the house, but that's the extent of my electrical work. :) Good on you!
Kick ass on the chemo. Double good on you!
Victorog
Victor
Houston TX
2023 f150 lightning
Construction
Amazing work and I can say without even knowing you, looks like a genius DIY pro. On the other hand God will give you divine healing ??. Thanks for sharing you got me thinking now, thought I was done with my set up got about 40% done??‍♂??‍♂?
21st Century Truck
Martin
An electric stove might indeed cook for hours, but its heating coil often is "on & off" and not a continuous current demand like a charging EV is. The stove aims to maintain a constant cooking temperature, which by definition means cycling the current on and off to counteract the constant incremental cooling of the cooking container. Hence, "on & off" at the receptacle, which makes a difference over hours of applied current and the resulting heat buildup at the receptacle.
Maineiac12
Iowa
This is awesome! I wish I had the skill and patience for this kind of thing. I’ve been meaning to install a generator inlet in my garage.
