Climate Start Failed - Error Message
roddiaz1
roddiaz1
Rod
Pittsburgh
Update:
Yesterday I opened and closed the frunk (making sure nothing impeded the closing).
I also cycled the climate settings on the Sync 4 control panel. First on to off, then back to on. Then I changed from Auto to Last Used Settings.
After making these changes, I was able to remote start the climate. And, the heat cycled on this morning per my scheduled start time. I noticed it had missed a few days this past week.
I really doubt the frunk had any impact, but I did it anyway. I do think that the cycling the climate controls was what made this all work.
Everything is working well now.
P.S. I wish I had isolated the experiment and done the frunk operation (open then close) and tested the remote start)
Not to worry, IMHO that might have been a coincidence in my experience.
Glad you have it working to your satisfaction!
markericha
Rich
2024 F-150 Lightning Lariat
Having the same issues since a few days ago.
So it seems after my update a few days ago, or maybe for no reason at all, my remote start and departure times have broken.
TLDR; seems like the truck is going into some kind of deep sleep and not responding to remote commands after a certain period of time. If I get out and walk away and hit remote commands within a few minutes;no problem. If I wait like an hour to lock/unlock/climate, I get a failed notification.
What Iโ€™ve noticed so far:
-Two days ago I left work at 5 expecting my departure time to be working and got into a cold truck.
-The next morning at 7:40 while plugged in it was working fine for departure time.
-I left work for lunch, hitting the remote start button 10 minutes before I leave, only to get to my truck and it wasnโ€™t on.
-I got to my daughterโ€™s school and decided to test it after getting out and into her school. Everything worked fine.
-Head to the gym, work out for an hour, and try to remote start before I leave. Nothing.
-Get back to work, try a remote start when I get to my desk, everything is working.
-a few hours later at work i try from my desk, remote start fails. I go out and restart sync, walk away and remote start, locks, everything is working again.
-5pm comes (a few hours later) and my scheduled departure doesnโ€™t work. I try it manually and it wonโ€™t respond.
Seems the truck โ€œgoes to sleepโ€ after a period of time and FordPass isnโ€™t t able to reach it.
Help.
GoodSam
Good
occupying space
As for the so-called "Sync" systems, I hate it when the Ford Navigation GPS location is lost when I am parked at home (a supposedly known location) and the charging goes to 100%, even though "one time" charging was set to 85% previously and no updates have come through lately. Last couple of days, my truck has either been in the ocean or deep in the roadless part of the national forest [even Android Auto is taken over by the Ford GPS for both G-Maps and Waze]. January, 2025, I will take it in for the latest Customer Service Programs and hope for that problem to finally go away after 2 years of not so intermittent problems. I wonder if Ford would give me a couple more years of free navigation before it runs out. Public charging location finding sucks as well.
Is it possible the GPS antenna has come unplugged ????
GoodSam
Good
occupying space
Tech replaced a cable connecting circuit board long ago for an attempt at a fix, but not reliable. If GPS was completely unplugged, I would expect no change in location when driving, but [AA and] Ford Nav just wobbles off road and leaves the blue breadcrumbs on the maps listening to Russian Global Positioning Satellites perhaps.
Maybe cooler weather has shortened the cables just enough to freak out the system.
But I was also waiting for the SSM 52574, APIM update needed to fix Sync4 static, etc, problems, to be ready to go...any idea on this SSM? There is a thread on this, I believe, from May, 2024? At least August: https://www.f150lightningforum.com/...4-solutions-being-developed.19619/post-411460
Anyone have access to OASIS to monitor the promise of SSM 52574?
Ford F-150 Lightning Climate Start Failed - Error Message 1734228766831-rk
Ford F-150 Lightning Climate Start Failed - Error Message 1734228910770-7u
Ford F-150 Lightning Climate Start Failed - Error Message 1734228803789-wi
Ford F-150 Lightning Climate Start Failed - Error Message 1734229009575-u7
What is your brand & model of phone?
GoodSam
Good
occupying space
Moto G Stylus g5 2024. An older unit was having Android Auto or bluetooth phone static problems. I would doubt the phone is causing the Nav GPS problems. Normally, only the Ford Nav was having a problem, not the AA. Android phone Maps work fine outside the truck, so I think it is Ford Nav messing up. I think someone had a pinched cable for one cause, but I do not know how the GPS antenna would be thrown off by X number of miles by a bad connection. I hope Ford dealer tech, Ford Engineering, has a permanent fix in January.
OK, was hoping your experience was not tied to this new issue
Ford F-150 Lightning Climate Start Failed - Error Message icon4
URGENT: Dec Android update for Samsung breaks PaaK
markericha
Rich
Help.
Just to update-I went to dealership and they tested the 12v battery and it was bad. I guess the truck was going into some type of low power mode and shutting down the telematics stuff after a while. New 12v and no issues thus far.
Mach Turtle
Central California
2021 Mach E, 2024 XLT
Bum
Update:
Today I tried remote climate start for the first time...and it failed, so I found this thread. A chance to do your test!
I've tried to duplicate the fixes that worked for others. Since I have an XLT, there's a physical climate control on/off button, and there doesn't seem to be an Auto/Last Used settings switch in the menus, but there is a physical Auto button, so I tried that. Results:
  • Frunk open, then close --> No change. 3 Honks with light flashes; "Climate start failed."
  • Climate controls off, then on --> No change. 3 honk-flashes and a fail.
  • Switch mode to auto (it hadn't been) --> Slight change. Two honks with flashes and a fail.
Not sure what to conclude except that there seems to be an Undocumented Feature in the system. This being a 2024 with update 10.1.1, it doesn't seem likely that it's just behind the times.
Update: Tried opening and closing doors with no effect. Also tried resetting Stynchโ„ข 4 by Microbesoftโ„ข and that didn't change anything either. No worries, I'll just figure that feature isn't present and live without it. Not that important in a mild climate anyway. Sorry I can't add a fix to the body of knowledge here, though.
TooManyToyz
Wisconsin
2022 Lightning Lariat ER
I'm having the same problem with the cooled seats. I remote start the climate and the cab gets nice and toasty, but the seats are on cool level 2. I'm up here in the frozen tundra where the seats are always set to heat, and I have the controls set to "last setting" what gives?
Try opening and closing all the doors.
Mach Turtle
Central California
Bum
Thanks for the idea; I'll try that during the daytime when I can do so without the risk of waking up half the neighborhood if it doesn't work. (Nothing personal, just that there's such randomness in most sophisticated software!)
Put the truck in run mode before doing the next remote start test.
The failed attempts may have extinguished the two remote start limiter before a run cycle.
