Instrument cluster doesn't turn on? Help
user-name-required
T
BC
2024 F150 Lightning Flash, 2023 ID4 pro S
Anyone encounter this?
Ford F-150 Lightning Instrument cluster doesn't turn on?  Help PXL_20250205_164457651~4
Drove kids to school, everything was fine. Took daughter inside, came back out and got into truck, and my instrument cluster didn't turn on.
Pulled over, parked, turned truck off, got out so it locked. stood there in the snow for a couple mins, then got back in. Still nothing.
Anyone have this happen?
(blurred the main screen for location purposes)
potato
BC, Canada
2023 F150 Lightning XLT ER
Yep, happened to me once, and there have been a couple of threads on it. I think there was some fuse you could pull to reset something but I can't recall exactly. Fixes itself after a while. Annoying driving without a speedometer. I have an OBD dongle connected so I can show the speed on the centre display using Car Scanner via CarPlay, but it's certainly not ideal.
Edit: here's the fuse info https://www.f150lightningforum.com/...r-has-gone-dark-fix-post-19.15413/post-333031
Maxx
Happened to me once after I remotely started the cabin heat, then got into truck and turned it on. Less than a minute after I left the driveway, it went dark. Drove back and used my ICE. Next time I turned it on, it was fine. Now I make sure I turn off the heat before I turn on the truck, in case the two are somehow related.
It's happened once or twice in the 2.5 years I've had my Lightning, with time it has self resolved.
What was your last update on the software updates screen?
user-name-required
user-name-required
T
BC
Thanks, I will take a look at that fuse thread. I did do a search for "instrument cluster" and didn't see the one you showed here
It's rare but has been reported before. I think one guy needed a new screen.
WaterboyNorCal
Erik
NorCal
2023 Ford Lightning XLT SR
Nunya business ;)
Happened to me about six months ago. Occurred twice in two days and hasn’t recurred since. I assumed that it was a software glitch.
ijustice
Jaime
New jersey
2023 f150 lightning lariat
Baller
Happened to me last week. Remote started climate, went out and blank screen. Drove about 40 minutes, got home, left it alone in driveway for about 2 hours, all back to normal. This needs to get fixed, it’s dangerous
ALAN BORER
ALAN
PALM COAST FLORIDA
2023 LIGHTNING LARIET , 2023 POLARIS SLINGSHOT , 2000 HONDA VALKYRIE
RETIRED
I had that problem maybe 2 times what I did is turned the truck off and then turned it back on and that worked maybe try disconnecting the 12 volt battery and then connect it to reboot !
Lucky number Fuse 13 in the passenger side fuse box. Careful, several people have accidentally dropped it and it was eaten up by a hole nearby. I think there's a spare but I forget the number. This resolved it for me. Only had it once in 2 years thus far.
Stalemate
Jeffrey
Seattle, WA
2004 Mustang v6, 2023 F-150 Lightning Lariat
Utility Electrician
Yeah happened to me once. I hopped onto the forums and read about fuse 13 so I pulled and reseated it and everything has been fine since.
Islandbumxlt
Todor
Friday Harbor, WA
F150 Lightning XLT
This just happened to me this AM. Was able to do it by just tapping at the #13 as i did not have pliers. But it came back right away. I wonder if it has to do with the fuse being a bit lose? '23xlt for reference as it appears mostly 23 models get some of this behavior. Maybe production line issue with a lose fuse.
user-name-required
user-name-required
T
BC
Happened to me about a month ago or so. Stopped at a convenience store, came back to the truck about 5 mins later after remote starting, no cluster.
Drive home that way, went inside to grab my computer to run some diagnostics, maybe 10 mins later went out and pressed the start button and its like nothing was ever wrong and hasn't happened again since.
Yea it's not happened to me even a single time since that one time in Feb when I posted this...
Hopefully it'll be the same for you too!
