- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 F-150 LIGHTNING, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
I was not happy that while I was out driving, an update wanted to install, but of course it is just a computer program setting that doesn't check to see if I am at home, on the road at a light, or whatever.These are inhibit updates. The popup likely said it would install at your scheduled update time and given the option to Install Now or Reschedule.
Were you driving at your scheduled update time (default is 1 in the morning)? Then it might have given that message.
However inhibit updates will not install unless the truck is off. So it would not have disabled you at a red light. There is also a countdown, two minutes I think.
However, it did give me the option to reschedule which I did just before the light changed to green. I was headed to a quick shopping stop and did not want to have to wait for an update to install at that stop.
It was distracting to have that pop up while I was out driving, stopped at a light, and I had to look away from the road, read a message, and select reschedule. I supposed if I had ignored it, it would not have disappeared and I could have selected reschedule when I got to my destination.
Yes, I think it may have been at the time I had scheduled for updates, which I have now changed to a time when I am not up yet or apt to be driving, but also a time when my overnight charging should have finished.
I had an update override a charging one time when I had them both set for 1am. I would have thought the charging would just be delayed or the update delayed, but no, the update installed but the charging didn't happen afterwards.
Maybe somewhere Ford mentions this could happen if they coincide - the update overrides and cancels the scheduled charge? Not the best way to have it programmed, in my opinion.
Luckily I didn't absolutely NEED the extra joules that morning, but if I had, it would have been a real pain.
