Fistandantilus
Germany
2023 F150 Lightning Platinum
Speedometer is displaying km/h now again. In easy mode I did the following sccm changes:
Speedometer calibration: Northamerica -> Europe
Display Unit Selection Function: Imperial -> Metric
Country Code: US -> CA (used CA as metric is used there too)
br
F.
In your original post the only SCCM changes you said you made were:
Blink 3 to 4
rain sensor disabled to enabled
Markt non-European to Europe
The blinks change and rain sensor are straight-forward.
I meant to ask you what you meant by "Markt non-European to Europe". Sounds like you may have messed something up there originally and Easy Mode fixed it.
EDIT: Are you sure you did this in SCCM? Those values seem to be in IPC.
Fistandantilus
Germany
You are right. I reverted in sccm the market parameter to non-European too - forgot to mention that. The other changes are from IPC, not SCCM - my mistake.
digitaldad
ABQ
'23 Lariat ER MaxTow
The spreadsheet says B stands for Background whatever that is. I have concerns when folks post mods that may come from the ICE forum or other sources.
I have a database of about 50 Lightning As-Builts across all model years and trim levels and everyone of them has a 4 in that position. I also have a few ICE Lariat and Platinum PowerBoosts in my data and they also have 4. But to your point maybe the original source was copying from an ICE F-150 that had a 6. I haven't added all variants of ICE to my data.
So I'm not sure why he disables SS but enables B ("2"). I agree with you that the logical value would be 0 if you want to disable the Splash Screeen. Did you try 0 and did it work for you? I haven't tried it.
In regards to "IPC Quick Boot"...on Saturday, I tried both:
IPC 720-07-01 xxxx xxxx 2xxx
IPC 720-07-01 xxxx xxxx 0xxx
No changes that I can see, looks stock/default (4xxx). I did reboot IPC modules after each attempt.
pdxmadman
Kent
Portland, OR
2023 Lightning Lariat Extended Range, Rapid Red
I've searched and I can't find anything about this. I have a 23 Lariat ER, is there anyway to add in-cabin propulsion sounds like the Platinum edition using Forscan? Not sure if I really want the faux sound but though it would be nice to have the option.
It may be possible but no one has discovered the changes. Many of these mods originate in the 14thGen ICE F-150 forum and they don't have any propulsion sounds (other than the V-6 or V-8!)
B177y
Olympic Peninsula, WA
Same here. I tried using the "easy method" too and still have the splash screens. 2024 Pro.
mhoffman54
Matt
Minneapolis
2021 F-150 XLT (302A), 2016 Harley Davidson Sports
Car Sales Consultant
I, too, would like to know this.
Gerstein1989
Alexander
Barrie, Ontario
2024 Lightning Lariat
Plumber
I’m trying to get glare free headlights to work but the section where you can set the direction of traffic is not there. This is all I got. Or is this how it’s suppose to look
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 imag
I don’t know what you mean by direction of traffic. Do you mean driving on the left?
That pic you have matches mine except that in the US we also have a toggle to disable Daytime Running Lights.
Gerstein1989
Alexander
Barrie, Ontario
Plumber
Ya I saw some people have a setting for driving on the left or right. I’m in Canada.
PJnc284
Garner, NC
yeah. Can't find the post but I also recall seeing someone with the setting. Must be some flag in FORScan somewhere.
Gerstein1989
Alexander
Barrie, Ontario
Plumber
Ya I was double checking all my changes and everything seems good. I even went for a drive. The high beams do turn on in low light conditions but there was no passing cars to see if the would move or dim. Whatever it’s suppose to do lol. With glare free you can’t even tell they have turned the high beams on. It gradually turns them on which is cool. The auto high beams would just turn on. It’s weird though, I thought Canadian trucks were suppose to come with it already activated.
A member entered a wrong setting during configuration and turned that setting on. See his post earlier in this thread. There are other settings in FORScan to configure RH or LH drive. This would be done by Ford when shipping to other countries as needed.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1742142938086-3y
