Ajzride
Alan
Houston
Eng
None of those affect compatibility directly. I say that because some XLT's and all Pro's don't come with ACC and the advanced version of LKA.
Just to clear up some confusion. All Lightnings have “Lane Centering Assist“, what you call advanced lane keep, built into the rack and pinion. Fords firmware just blocks it if the ACC radar isnt detected or has error codes. If you add ACC to an XL, Lane Centering Assist will work.
Ajzride
Alan
Houston
Eng
Someone on my youtube channel today said they were able to eleminate the startup errors without a harness extension by putting ferrite chokes on the comma power cable (between the ODB2 port and the harness box). I cant understand why that would work, but it is worth having someone else (who doesn't have an extension harness yet) test out.
Drayday55
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
That's a good idea. I only have modified harnesses now but I have one coming in the mail. I'll give it a shot. Did he say what size? I have choke for my treadmill motor mill. It's big but I'd be curios to know the smallest we can get away with... but i thought thay the power from the obd2 wasnt required for the comma to run?
Ajzride
Alan
Houston
Eng
It’s not. I guess we should also try with comma power unplugged and a short harness.
PaulStew
Paul
2023 Lightning Lariat
Programmer
Have you guys been able to test out the ferrite chokes?
Ajzride
Alan
Houston
Eng
Andre was going to next time he got a short harness to modify. Since my truck is an ICE i don't have any issues with the stock setup.
PaulStew
Paul
Programmer
If you point me to the ferrite chokes to buy on Amazon, I’d be glad to try. I’m still using an unmodified harness with the annoying warnings.
Ajzride
Alan
Houston
Eng
Do you have the old style harness or the new one? I found out with the Mach E this weekend that they behave differently for some reason I can't decipher yet.
The first test would actually be to just unplug your ODB2 connector and see if the errors go away. If they do, then buy these:
https://www.amazon.com/20pcs-Clip-Ferrite-Suppressor-Diameter/dp/B0CSXZWGD6/ref=sr_1_3?crid=1IGXPEU69523W&dib=eyJ2IjoiMSJ9.rdCMnR6pY0gdH79daxUhaH5CV6DSA9a8YfGH9OF8w8GXKPutH2MdAv9ypiSX_FdlvbswYJ-9JqZMdYM8a0LOx7GL434YGjn3x5n0eq32miiUvo5XQjzY-ywT7KlzvcXIXKNmALFYFO74udnNzmvPB5t_K-NZp67c12UnenkxDVq9mOxKQs3UhpekYk5-nsq5SFRbnPUumW2_FScyKyzBba-Gvvy8WqiHnAns5oRNTjI.BGglZGz26eeK1nNr3f3s_7EPmDvcSsSN1MAYFFx8bsQ&dib_tag=se&keywords=ferrite+choke&qid=1744665737&sprefix=ferrite+choke,aps,176&sr=8-3
PaulStew
Paul
Programmer
I have the newer harness. I don't actually use the ODB2 connector, just a long usb cable.
Ajzride
Alan
Houston
Eng
Andre tried the ferrite cores on his USB cable at the very start of this thread and it didn't help. The youtube guy said putting the ferrites on the power cable helped, but if you aren't running the power cable then you can't put the ferrites there.
UncleTony
Tony
Cybersecurity Engineer
I wonder if there is a large amount of EMI on the lightning due to the proximity of the front drive motor and or the high voltage runs that sit almost directly under that kick panel. I can't think of another reason of why the ICE would work fine and not the lightning.
I have seen speculation that the can bus system may differ between the two, but I can't imagine ford would completely redesign their communication system unless they were forced to. The fact that the Mach E doesn't share the issue seems to support my personal theory. (Also considering the fact that ICE owners can use generic 6 foot USB C cables without issue).
I just bought the wife a new Blazer EV so I'm not fully ready to jump into testing my theory's (as I would have to buy a unit), but man it is tempting, especially to be able to have self driving on non mapped roads.
Ajzride
Alan
Houston
Eng
it’s not EMF, it’s canbus reflections. We think the reason the Lightning has issues and the others don’t is that Some of the modules on the Lightning never go to sleep (and are awake during boot up on the Lightning) which is related to the reverse power (power the house) capabilities the Lightning has.
if it was EMF the resistors wouldn’t help.
UncleTony
Tony
I may sound ignorant by asking as I am not super familiar with canbus designs, but wouldn't that mean the issue could be fixed without the harness extension and just the resistors as it should remove the reflections? (My understanding so far is that the extension is to add the resistors and allow the use of the stock USB C cable).
If that's the case, they could just add resistors to the Q4 harness and sell it as the lightning harness.
It should also in theory not have a negative effect on other vehicles as that is considered a proper termination by canbus standards (again, just from my understanding).
Ajzride
Alan
Houston
Eng
Because the resistors have to go on the end of the canbus stub, not the beginning. I guess you could make a custom USB cable with resistors, but that seems harder than an extension.
