Modem
TheDuck
Charles Harris
2024 F150 Lightning Flash
Modem not working.
I noticed that my truck info on my phone was not updating.
Called Ford Pass and the rep went through a series of diagnostics to determine that the modem, in the truck, was not working. It will go into the shop at the end of the month. Four months old and less than 1500 miles.
Anyone else experienced this?
TheDuck
Many.
Pull the negative lead off the 12v battery for 20 min, then put it back on.
12 v disconnect as @RickLightning notes. There are settings that will also prevent your app from getting updates. Double check those setting about connectivity and make sure they are all on after you reconnect your battery.
On the Road with Ralph
Ralph
Mojave Desert, California
2023 Ford Lightning Pro
Real estate/biz consultant
Fuse 32 in the passenger footwell is the modem if you don't want to disconnect the 12v.
I’ve generally found this modem reset easier and quicker than disconnecting the 12v LVB. It also seems to the reduce the number of infotainment settings I have to re-enter.
Ry2023
Rick
Pa
2023 f150 lightning
I had the same problem with my 2023 er ..pulled fuses, a bunch of times…. Called Ford….. the only thing that worked is I took it to the dealer and they replaced the TCU…. And it has worked great ever since without any issues…. Was covered by warranty
mb0220
Matt
2022 Lariat ER
Same here - 12v disconnect would not solve the issue. Although in my case the dealer had to replace the gateway control module.
NCevGuyF150
North Carolina
22 Ford lightning
Repair technician
Modem not working.
TheDuck
Yes, I had that exact same problem when my truck was a day old. I took the negative terminal off of the 12 V battery for about 20 minutes and reinstalled. My truck started to update and everything worked fine after that.
MountainAlive
Massachusetts, USA
This happened to me when I first bought my truck. Nothing worked except finally replacing the TCU / modem.
Ry2023
Rick
Pa
2023 f150 lightning
My issue was from day 1 as well
Yubbs
@024 F-150 Lightning Lariat
Happened to me twice so far, both times disconnecting the battery fixed it almost immediately. Only thing is make sure the charger is not connected also, only worked when I disconnected that also.
