NHTSA Recall - Loss of Steering from Front Control Arm Separation (Impacting certain 2023 to 2024 builds)
Mike G
N. AL, USA
Safety Recall 24S76 - Certain 2023-2024 F-150 Lightning Battery Electric Vehicles - Upper Control Arm Ball Joint Nut Replacement
Okay, so NOW the full recall has been released as of this morning (5 Feb '25). Number of vehicles went down by 2 (I assume they've already fixed those as part of the validation) to 11,291.
The date range was expanded by a day on either side of the original range, so that's now 5 November '23 to 13 February '24 inclusive.
Every one of the trucks are going to get something. Meaning when they do a torque check to find out if the nut meets the check spec...even if it passes the nuts are replaced anyway. If it doesn't pass the initial check the whole steering knuckle gets replaced.
Riverant
MA
2023 F150 Lightning Lariat ER
Had this done by mobile service today, at least the inspection. Torque checked out and the nuts were replaced.
Also on the plus side, the tech agreed to update my BCM so I now have walk away lock.
NikonJim
2024 F-150 Lightning Flash
Same for me on the recall, but I already had the walk away lock.
Literider150
Brad
67 Deer Trail
2024 F150 Lightning
I took my 2024 Flash in on Feb 12 as it was in the recall window. The mechanic that finally checked it out met me out front and assured me - with a huge smile- not to worry that he inspected it and deemed it ok to drive. No worries. He seemed to think it was kind of funny, even though loss of control while driving is anything but a laughing matter.
They told me that they ordered two bolts; I guess one for each side. No mention of torquing the nuts or anything like that. My Flash is a Dec. 2023 build. I haven't heard from them yet.
PJnc284
Garner, NC
Well my nuts were loose. Have to go back when they get the parts. Service advisor mentioned the fix was listed as taking 3 hours so we'll see how long it takes them.
sean7512
Sean
Pittsburgh
2024 Lariat | 2023 MachE GT
Looks like this was expanded today (May 27, 2025). My truck was not part of the original recall but it is now showing on Ford's site and the NHTSA with today's date.
EDIT:
This may be a new/separate recall, but similar in nature.
Ford F-150 Lightning NHTSA Recall - Loss of Steering from Front Control Arm Separation (Impacting certain 2023 to 2024 builds) 1748366238604-tc
VAL.ABAPO
2025 F150 FLASH LIGHTNING 131kwh ER
EDIT:
I just got my Truck last week and I was hoping mine wasn’t affected. Thought wrong. Now the hassle of taking the Truck to the dealership and lose a day of work??‍♂
PJnc284
Garner, NC
This reminds me that I need to call my dealer. Been about 3 months since I took mine in and they told me it was out of spec and they needed to order the new knuckles.
footballfalex
Alex
F150 Lightning 2024
My May '24 build date 2024 is now being included as well, so looks like the scope expanded by quite a bit.
Whammy Bar
Do none of you "truck people" own a torque wrench? Set it to 45ft-lbs and go find out.
Ford F-150 Lightning NHTSA Recall - Loss of Steering from Front Control Arm Separation (Impacting certain 2023 to 2024 builds) 1748454214199-gc
If its loose, make an appointment at the dealer. If its missing... make an appointment at the dealer.
brirr76
Midwest / KC
2024 F150 Flash / 9.6kw + Max Tow - Midwest / KC
I also have the May 2024 truck and just saw the recall appear this morning on the Ford app under Service - Recalls.
Darn.
sean7512
Sean
Pittsburgh
Dropped my truck off this morning....we'll see. Hopefully all is well.
VAL.ABAPO
Mobile Service is coming for my 25’ Flash
FloridaMan655321
1973 F100, 2024 Flash
Has anyone had this issue? If so, what did you notice before the issue happened? I noticed there is a strange creek when I turn the wheel very hard, but I only hear it if the window is down. Hasn't really been an issue, but just wondering if this is related.
