Uhhh, seems a bit fast for the neighborhood... (80 in a 35???)
I think it’s been discussed here before and seems like it has to do with software reading a roadside sign that is not a speed limit sign. Like an exit sign or weight limit sign, etc.
Mine does it even with no signs of any kind in view. The system also uses a database for speed limit data. There were locations in my town where it would inexplicably drop to 20 in a 30 and show 70 in a 35. It was 100% repeatable and eventually got rectified.
I’d also mention that even with “Speed limit assist” turned off, you can still see the errors on the display.
Citizen0
Seth
Georgia, US
2022 F-150 Lightning Lariat ER, Anti-Matter Blue
CTO
Yes, it's definitely a mix of a database and actual sign recognition. There is a section of Highway 41 that is clearly marked 45, but the database overrides that to 55 several times when speed sign recognition is turned on. There is another section in front of our technical college where Val-Tech Road parallels Interstate 75 and it thinks the road's speed limit is 70 instead of 45.
Always remember these are "assistive" features. I've learned the areas I drive most commonly and know when to disable cruise control. I'm especially cautious in areas I'm unfamiliar with.
I do leave speed sign recognition on as I had rather driver slower in case _I_ miss a speed limit sign. If the truck speeds up I assess the situation and manually change speeds accordingly. I use Car Play with Apple Maps which also has speeds listed and will usually default to the lower reported speed if there is a mismatch unless I absolutely know otherwise.
Caliber357x
‘23 Lightning Platinum
Mine does this on specific roads - notably Corridor H which is also known as WV 48/55. The speed limit is 65, and there are many 48/55 signs along the 20 mile stretch I frequently drive, but one sign in particular it always misreads as a speed limit sign, causing the brakes to slam to drop me from 73 (+8 cruise tolerance) down to 63. It also does this when I’m on I-66 (express lanes are 70, regular lanes are 55) even in the express lanes, the truck will sometimes slam on the brakes, picking up a 55 sign here and there.
@Ford Motor Company really does need to focus on this and develop a solution or solutions.
bryce
Bryce
2023 Lightning Lariat ER, 1999 Boxster
I also live in Portland and have found a stretch of Broadway where the system occasionally thinks the speed limit is 80. Near a gas station, so their sign might be leading to confusion.
I also find that it reads the speed signs on side roads which here are 20 mph, and so the truck will want to slow down.
I enjoy using the ACC, and like how the speed limit correction works on the highway, but there are still serious issues when on city streets. It would be great if there was a way to set preferences for city streets vs highway. But for now I have the automatic speed adjustment turned off.
Sneakypetie78
Pete
Marina del Rey, CA
2023 F-150 lightning Lariat
General Contractor
Lol... the song on your radio..
Creeping death is what the pedestrians are about to experience once your truck hits 80 mph.
Mal106
Mal
SW VA
2025 Lightning Flash
Retired Pilot
I do the same. I have never had it fail as far as I know because if the truck accelerates, I watch it like a hawk. My '23 Powerboost was the same though occasionally it would see a speed limit sign on a parallel or crossing road and slow. Even that was very seldome. I didn't like it at first and wish the offset was in percent rather than absolute but now I like, even depend on it. As I get used to the automation and nannies I like them all. Admittedly that may have something to do with how many times I've rounded the sun.
Marc
Marc
Roswell
23 Lariat and a 24 Model X
insurance agent
I had this happen yesterday! I was cruising with Blue Cruise going and my truck would randomly accelerate to 80 miles an hour! It happened 5 times. No signs on the road I was on interstate 16 in Georgia . I also had sync freeze and not allow me to cancel route planning.
nodoubleg
‘15 Jeep JKU, ‘89 E-250, ‘98 Dodge Ram 2500
I’ve turned it off because here in Michigan, you deal with a lot of construction. Speed limit 60, unless workers present, then 45. Truck will “snap” to 60, then 45, then 60 again.
I suspect the IPMA doesn’t have the horsepower necessary to run an AI model large enough to make determinations on things like speed limit signs and figuring out which one you need to obey. Based on the quality othe the other cameras on the truck, I suspect the cameras Ford used for bluecruise are also probably pretty cheap as well.
I think that the vehicle will end up needing to be able to read and parse the language on traffic signs to be able to do the right thing. When it’s finally reliable, cars will probably end up with better reading comprehension than the average American driver!
I don’t expect the Lightning and its IPMA to ever get there. I think Ford will take a while to get there even in future vehicles, judging by the pace they are operating at. For us Lightning owners, I think that means switching to Comma AI at some point if you want something better than BC 1.4.
If they keep the yearly price of BC as high as it is, switching to Comma AI is probably likely for me once my 3 years + $0 additional year are done (which is …late 2027).
priceb
Price
Western North Carolina
2023 F150 Lightning XLT SR
College Instructor
Prior to the most recent IPMA update mine would misread a Highway 107 sign in a school zone and think the speed limit was 100mph.
Scorpio3d
SS/IBA car wash owner
I know my truck always recognizes school zone speed limit signs even this time of year when school is out so even if the speed limit is 30 or 35 or 40 it will show the speed limit sign on the screen as 20-i’m not using cruise or anything. It just shows up on the screen because it read it.
