Comma AI self driver assistant On Sale- is it worth it?
spadesaspade
Spadeit
Pennsylvania
F150 lightning, Hyundai Sonata
A few of us on here retrofitted it into the PRO and base XLTs for the ACC/Lane Centering function.
I looked up the retrofit a while back. But from what I remember, I do not have the right wiring in my pro to be able to retrofit the radar assembly. I'm missing some wires in my wiring harness and hence cannot use the wiring harness to connect to the radar.
jdmackes
2023 F-150 Lightning Pro
If that is the case you'll just need to run 4 wires from under the glove box to near the front bumper (if I remember correctly, mine had the wiring so I didn't have to run them). It's not difficult and you just need to buy some wiring and the pins that would then go into the existing wiring harness. Lots of people have done it
jdmackes
I've retrofitted my Pro for the adaptive cruise control, would the comma work for me? I can't remember if there is a difference between ACC and the Co-Pilot 360 2.0 the website talks about
3rdgenfan
Geoff
Delaware
Cybersecurity
B177y
Olympic Peninsula, WA
2024 Pro SSV ER Max Tow
Same here. No wires were present in my Pro. About halfway through the ACC thread someone figured out that it's easier to just make your own 4 wire harness with one end at the new CCM, and add pins to the to IPMA plug. It sounds bad but was pretty easy.
I added a Comma a little over a month ago to my Pro with the above ACC mod and it's AWESOME!
pookguy88
cars
can anyone confirm if this works on a 2024 Flash? I thought I read somewhere that 2024+ F150s don't work with Comma because of some new encryption?
B177y
There's a few 2024's of varying trims, including my Pro, running Comma's.
2025's have encryption and are likely not able to work with the Comma. 2025 Mach-e's are confirmed not to work but I haven't seen someone with a Lightning actually write about if they have tried yet, but the people that work in the field say it won't.
Ajzride
Alan
Houston
Eng
confirmed working for all 2024 with adaptive cruise. There was some early confusion about whether 2024 had encryption, that has been cleared up.
copbait
James
2023 Ford F-150 Lightning XLT SR
Physical Therapist Assistant
I'm glad to read this has been done, I've got my comma being shipped already, I did the ACC retrofit a few years back. I finally became a member rather than just browsing the forums.
It's @branden fault I am now almost $1,000 poorer. His latest YouTube video pushed me over the edge!!!
ScottyG
Scott
Ford Lightning XLT
Does this work on a 2022 XLT 312 package?
watts/up
23 Pro SR
Anyone who already has a Comma: do you have an OBD-II splitter you would recommend? Anybody experience issues using one?
B177y
I have this two-way (currently available), and a four-way splitter that doesn't seem to be available any longer. Both work great. Not an affiliate for either.
EDIT:
You actually don't need the OBD for the Comma. The OBD power allows the Comma to stay on in standby mode when the vehicle is off. Without the OBD it restarts with each start of the vehicle. It boots quick enough that it's not an issue unless you are doing lots of testing or trying different software versions.
watts/up
23 Pro SR
Thanks. I think I’ll try it without the OBD and see how it goes.
