What did you get on Prime Day? Let’s share!
TripleAliners
Diamond Sponsor
www.amazon.com
F150
Drop your haul below and let's swap some shopping inspo! ?️??
BTW, our mats are about 20% off right now — plus there’s a giveaway where you could win one for free!
Come take a look at our post! ?
Giveaway
Tree RX
Red
2024 Lightning Platinum
Tree Dr
Been thinking about getting a dash cam…Pulled the trigger on the fitcam prime deal
I was thinking about doing the same thing, but couldn't make up my mind.
ericpullen
Eric
Louisville, KY
I bought an Anker F3800 Plus to be the primary power for my house in storms, as well as the generator inlet so I can recharge it from my Lightning!
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
Another copper press tool for plumbing.
Softball First baseman's glove because it was a great deal.
A 6 piece set of Annular cutters from 1''- 2'' for my magnetic drill press. If you never used or heard of a magnetic drill press, look it up. drills steel in place and drill like it's butter. literally like a milling machine / drill press that sticks to the metal with an electro magnet.
Rick
Migaloo
adam
24 Lightning Flash
Covertopia seat covers. 20% off.
One camera watches the front the other watches your rear. 2 cameras.
Oh, the others dash cams just say front + rear so that was the first place I've seen that mentioned channel. Seemed weird but it's just different wording. Thanks.
Magua
2024 F150 Lightning Platinum
I got a dash cam: I was trying to decide between the DashcamX for easy/clean install or go with a VIOFO A229 that is known to have a better quality camera. So I pulled the trigger on the prime day sale and the extra $15 off with the coupon code on the VIOFO.
VIOFO A229 Pro 4K HDR Dash Cam $227.99 w/ promo code VIOFO2025
Vulnox
Livonia, MI
Only stuff I got for the truck were some plug adapters. We stayed at a house over the 4th holiday weekend that had a 30 amp TT outlet, but I didn't have an adapter for it. So I picked out a few different adapters for different 30 and 50 amp outlet styles.
Now I need to find a portable charger that allows you to adjust amperage and doesn't break the bank. The Lightning Charger worked well for us, but if I read it right on here it's still a 30 amp charger, and on a 30 amp outlet that can be a bit dangerous. Unless it's actually 24 amps.
potato
BC, Canada
2023 F150 Lightning XLT ER
If it's a 120V 30A outlet you'll be disappointed. The Lightning will only charge at 12 amps on 120 volts no matter what EVSE you use.
Plug adapters could be useful though. 12 amps is better than nothing in a pinch.
Getting off topic but I went with the Tesla UMC because of the variety of adapters available. Of course I wouldn't recommend Tesla anything now, but the product is fine.
Vulnox
Livonia, MI
Ah yeah, I knew most TTs are 120V and that the outlet is a TT-30, but I wasn't putting those things together that I would likely still be limited to 12 Amps anyway as you said. Ah well, good to have the adapter in case that's the only outlet in an ideal location.
Good to know about the Tesla UMC. I think I see them being sold on places like Facebook Marketplace and eBay. I have the Tesla to J1172 adapter so that may be a decent option if I find one for sale used for cheap enough. No real harm in buying used Tesla stuff. :D
