PU-Sync-25.2.1.6.5 - Walk Away Lock Toggles: Post 203 Final FIX!
SeanOC
LINY
‘18 Raptor ‘21 Tesla Model Y
Pilot
I’m one of those guys who leaves a key fob in the truck at all times. I’m assuming WAL would not work for me? I know teslas work even when you leave the credit card in the car, it’s solely based on your phone
MichaelCA
MichaelCA
'22 Lighting ER, '22 Tesla Model 3, '16 Mustang GT
The credit card doesn’t have active signaling so the Tesla wouldn’t even know it’s there. You can faraday bag the fob though.
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
What the truck is showing
Ford F-150 Lightning PU-Sync-25.2.1.6.5 - Walk Away Lock Toggles: Post 203 Final FIX! IMG_4444
Ford F-150 Lightning PU-Sync-25.2.1.6.5 - Walk Away Lock Toggles: Post 203 Final FIX! IMG_4445
SeanOC
LINY
Pilot
If only the update actually worked! Like others I received the update but no toggles in menu and when I removed the key fob to test the feature it doesn’t work. Well done again @Ford Motor Company
Ted23Lightning
Ted
It’s not showing the options for it :frown:
Ford F-150 Lightning PU-Sync-25.2.1.6.5 - Walk Away Lock Toggles: Post 203 Final FIX! IMG_4449
Ted23Lightning
Ted
abcut973
Anthony
Denham Springs
I don't recall if this question was answered before but do we need to have the phone as a key to benefit from the WAL?
I have the toggle - but as soon as I select "enable" it goes right back to "disable". This is despite getting the announcement in the "Update details" - Maybe I need a 12V battery reset cycle?
No, this is a two-part update. You still another update for the BCM in order for it work. The release notes should have some kind of disclaimer saying something about this, but it does not. Either way, you got newer Sync software that most likely has other improvements built into it. Eventually, the update you need for WAL to actually work will come in.
daveross1212
NY
'21 Tahoe Z71, 22 X5 45e, '22 F150L Lariat ER
I have the BCM update (thus WAL is enabled), but I can't turn it off. I got this update, but I still can't turn it off. Seems like Ford missed something in this release ... like the actual change described? (yes I know it can be done via forscan)
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
No, WAL does not require PaaK.
