srowley
I have a 2024 Flash with the 131 kWh extended range battery. I have read through all the other posts on range. Many say don't pay attention to the Guess O' Meter (GOM), just the mi/kWh. I disagree with this. I put 100K miles on a 2017 Chevy Bolt and have a 2023 Bolt with 20K miles on it. They both have always tracked the expected range or been above it. The GOM in my Flash is always way below the expected range. I can't just ignore the GOM and go by mi/kWh. That is like saying "don't pay attention to your gas gauge". When I am driving a long distance I have to plan my charging based on the GOM, so I am bummed out that the range is so much lower than the advertised range.
Of course it all depends on how many mi/kWh you are actually getting. Based on what my truck is reporting as mi/kWh, I should be getting a range of 299 mi at 100%. Instead, the range reported by the GOM (extrapolated to 100%) averages at 248 mi. The point is that one of these is wrong, either the GOM is off or the mi/kWh is off, but I still have to manage my charging based on what is reported by the GOM, so I am effectively getting a reduced range.
I have attached a spreadsheet of my driving over the last 1500 miles from June 20 to July 27. The key values in this file are:
1) column B: the GOM calculated total range which is based on the displayed range and percent of charge
2) column H: the Trip Range which is calculated by multiplying the reported mi/kWh by the battery size, 131 kWh
3) column I: compares the GOM Total Range versus the Trip range (calculated based on mi/kWh)
4) row 12 is the key comparison showing the average GOM Total Range (248) versus the calculated range based on the reported mi/kWh (299).
The point is that one of these has to be wrong. The GOM should be based on the mi/kWh from actual driving. I find this completely unacceptable to have the GOM Range so much lower than the mi/kWh. I plan to report this to Ford, but not sure how to do that.
I'm interested in feedback from the forum on my detailed range analysis, findings, and what to do about it.
