DAS640
Daniel
Beaufort, SC
2024 Lightning Flash
HR Officer
No, just trying to separate the normal startup errors. If you are still getting errors, it is likely you have a hardware issue. Most of that should clear once openpilot/bluepilot takes over. Are you able to make a breakout board?
I am not that good, although I did pay my deposit today. I suppose I could give it the old college try. Always up to learning a new skill
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
I know you already tried another cable, but you can try removing the comma from the windshield and plug it directly into the harness box with the shorter 90 degree that comes with it. It's always possible the coupler is bad.
DAS640
Daniel
Beaufort, SC
HR Officer
Progress. No codes attaching the short 90 degree cable directly to the harness
UncleTony
Tony
When you used the other (long) cable, did you have the purple coupler in place?
If you did, try both cables plugged directly into the comma. Nothing else inline.
DAS640
Daniel
Beaufort, SC
HR Officer
When you used the other cable, did you have the purple coupler in place?
No. Not with the short cable. plugged directly into the harness. no coupler
UncleTony
Tony
The long cable (both of them, throw codes immediately) same issue as before
They are expected to throw codes immediately. We need to know if they go away after the software is fully up.
UncleTony
Tony
If your comma looks like this and you are still getting errors on the truck is what we are looking for.
Ford F-150 Lightning Comma AI self driver assistant 20250811_195149
DAS640
Daniel
Beaufort, SC
HR Officer
Happy to report I have taken my first drive with a fully functional and operational Comma.ai. Thank you both for your assistance. Should I just wait now for the breakout board and just do a start up according to these simple tests till then?
UncleTony
Tony
The only thing you should have to do is wait for the software to boot if you were able to get it working. Is your AC working?
UncleTony
Tony
DAS640
Daniel
Beaufort, SC
HR Officer
I would recommend waiting for the next batch of adapters since you aren't having any major issues. You can reserve one here. https://bluepilot.dev/lightning-coupler-order-page/
First off a big shout out to both UncleTony ad Ajzride in helping me getting my comma working on my 2024 F150 Lightning Flash. As a side note the factory long USB cable would not work. I used a USB C 3.2 Gen 2X2 Video Cable, 20 Gbps Data Transfer, 240 W, 10ft, and that is when the comma finally came to life and the error codes disappeared. I have paid the deposit for the adapter and cannot wait to put in on. Thanks again. What a great forum.
DAS640
Daniel
Beaufort, SC
HR Officer
