Rotary Shifter Part Numbers
UncleTony
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
LX6Z-7P155-A is motorized with ambient.
Ford F-150 Lightning Rotary Shifter Part Numbers 20250902_105253
F150Redux
Daniel
2025 F-150 Lightning Lariat
Computer Geek
I got it on ebay for $100. It was the only one he was selling though unfortunately.
Yeah, I'm not seeing that anywhere.
What I am finding is the replacement, LX6Z-7P155-U, but they want like $225 for it.
UncleTony
UncleTony
Tony
Yeah. This one was a lucky find. It had only been up for a couple hours when I happened upon it.
UncleTony
UncleTony
Tony
What tabs are you filing off and why?
The mounting tabs, So it will fit in the cubby. I like this design much more than the ones with the mounting holes on the bottom.
HisSvt2
2023 F150 Lightning 2024 Mustang Mach-E
Admin
Tried looking for pictures of what you’re explaining but haven’t found any . By mounting tabs do you mean in the truck or on the new parts? Just curious because I would what this reversible if need be .
UncleTony
UncleTony
Tony
https://www.f150lightningforum.com/forum/threads/rotary-shifter-part-numbers.29588/post-551503
You file the mounting tabs off the rotary shifter and it drops in. It gives you more storage space and I was able to swap it without taking my console apart. It doesnt effect the ability to revert the truck itself back to stock. Only difference is that you end up with a rotary shifter without mounting tabs. I didn't like the idea at first, but tried it anyways and am glad I did.
Ford F-150 Lightning Rotary Shifter Part Numbers 20250902_114325
T3Fan
NJ
2025 Lightning
I just received my LX6Z-7P155-U from eBay. What is troubling to me is that I do not see FoMoCo stamped on the part, or the actual part number for that matter. It looks like they have been scratched out.
I am going to attach the eBay listing I purchased from along with an image of the part. Maybe someone can confirm they purchased from the same seller and installed without any issues. I am hesitant to even install it.
I am in the same boat as UncleTony. I feel like I want a motorized dial with an illuminated base/ring. However, I am having some trouble locating that.
I haven’t been able to find a lit base and motorized so I’m just going with the lit base for now.
UncleTony
UncleTony
Tony
I am able to sell the PZ1P-7P155-AC now if anyone wants it. I can print the cubby for you as well since it doesn't have the mounting tabs. It was brand new a couple months ago. Figure $120 including shipping is fair. (Saves about $40 compared to buying the shifter and $70 for the etsy print).
That is if @opioid doesn't want it.
HisSvt2
Admin
Thank you for explaining . So I don’t have to do this with the one I’m using.
Ford F-150 Lightning Rotary Shifter Part Numbers IMG_9146
UncleTony
UncleTony
Tony
Correct, the shifter should mount on the bottom and use the stock mounting points of the shifter.
UncleTony
UncleTony
Tony
Here are those additional pics of the part I promised. I tried to take them with as much daylight bleeding in to aid in visibility.
if you look real close to the scratched out section, I can make out a Z and P. It shows up better on the first picture I posted.
I think this may be motorized. Between the two I have (One motorized and one not) yours looks like the motorized version - 4 screws on top and the diamond bottom.
T3Fan
NJ
2025 Lightning
For the non-motorized, would the silver ring free spin, or be locked into place when it's not hooked up?
