Footprint of 131Kwh battery vs 98 kw battery
blueI5land
D
Palm Beach, FL
F150 Limited PB
Are they the EXACT SAME? same connections? same EXACTLY? in other words if both were laid side by side would there be ANY difference other than weight?
RLXXI
S. E. Louisiana
Automotive Technician
The outter can is the same, one has more modules inside than the other.
P-38
2024 Lightning Lariat
And the modules are different inside, not just more. I forget how exactly. It's in a thread somewhere.
I think there were 2 or 3 different module sizes. They pulled the smallest module out for the new reduced capacity ER trucks I think.
IIRC the ER battery has a second layer with additional modules. So same case, but the top lid is taller.
I have not seen a SR battery to confirm but I assume the top lid is flat.
I could be wrong on this, I have only seen the ER battery, but it was my understanding the SR was one layer, the ER added a\the partial second layer.
Wrong...see below
Man, everybody is "remembering" wrong. :facepalm: There are three different size battery packs. The original 98kWh SR, original 131kWh ER, and the 123kWh Medium range (for 2025 Flash job 2*)
All three packs have 9 modules - 6 on bottom, 3 on top. The number of pouch cells in each module differs. Here is a post where the nitty gritty details are:
https://www.f150lightningforum.com/forum/posts/488187/
Basically the ER has 8 large modules and 1 small. The SR has all 9 small. And the MR has 6 large and 3 small.
* - also the ER Pro for fleets
RLXXI
S. E. Louisiana
Man, everybody is "remembering" wrong. :facepalm: There are three different size battery packs. The original 98 SR, original 131 ER, and the 122 Medium range (for 2025 Flash job 2*)
123kWh for the mid range pack. It's what I have in my 25 Flash.
watts/up
23 Pro SR
At one point In the OOS video of the Lightning production line Kyle asked the Ford rep which battery they were looking at and he said you couldn’t tell just by looking at them so this makes sense.
Reactions: chl
Thanks for the correction!
If I got the information down correctly:
480 cells = 131 kwh battery in the ER (8 x 55 + 1 x 40) or 96 series groups of 5 parallel cells - 8 x 15kWh and 1 x 11kWh
450 cells = 123 kwh battery in the Flash (6 x 55 + 3 x 40) or 90 series groups of 5 parallel cells - 6 x 15kWh and 3 x 11kWh
360 cells = 98 kwh battery in the SR (9 x 40) or 90 series groups of 4 parallel cells - each module = 11kWh
They all have 9 modules and the 9 modules all take up the same physical space in the truck.
Also, the SR and Flash have one 11kW charger, while the ER has two 9.6kW chargers.
RLXXI
S. E. Louisiana
Numbers are skewed due to the fact you're calculating it based on energy available for use, the packs themselves are larger in capacity than the stated usable capacity.
Reactions: chl
True, just going with the numbers I got from a Ford source - net not gross. Unsure what the buffer sizes are, but all that really matters to the user is the net-usable size anyway.
RLXXI
S. E. Louisiana
True, just going with the numbers I got from a Ford source.
From the owners manual link in Ford pass for my truck they show this info and I have the 123kWh rating.
Ford F-150 Lightning Footprint of 131Kwh battery vs 98 kw battery Screenshot_20250907_105300_Chrom
P-38
Of note starting in 2024 all models have a single on board charger. Unless it was a fleet model that was ordered with dual on board chargers.
Reactions: chl
Thanks, nice chart. I didn't know what the "buffer" capacity was.
I suppose the difference between 123kWh and 142.1kWh is the "buffer" extra battery capacity for health so the battery does not get too close to actual 100% or actual 0% controlled by the BMS (battery management system).
Sort of like gross and net income. The "usable" capacity is the net.
PS: AI had told me this but hadn't seen it in writing from Ford.
"The F-150 Lightning Extended Range has a total battery capacity of approximately 146-148 kWh, with a net usable capacity of 131 kWh"
