Enabling charge speed on dash.
Interesting mod. Thanks for the write up. First time I’ve seen module reprogramming using Forscan detailed. I’m confused about the memory space related to putting a 2024 firmware on a 2022/2023 module. And how that is/was fixed.
@ZSC100 , I thought I knew all the acronyms. What goes EG stand for in F150 Lightning XLT SR EG 311A?
PJnc284
Garner, NC
Compared the values for changes I made (glare-free, shutdown timer, seatbelt reminder, chime on startup, and door ajar) and all addresses and values appear to be the same between the regular and 2024 tab in the livinitup spreadsheet. May just try reverting those and see what happens.
Ford Motor Company
Official Ford Account
F-150 Lightning
RLXXI
3rd rock
Automotive Technician
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Compared the values for changes I made (glare-free, shutdown timer, seatbelt reminder, chime on startup, and door ajar) and all addresses and values appear to be the same between the regular and 2024 tab in the livnitup spreadsheet. May just try reverting those and see what happens.
The issue is that there is mismatch in the config memory structure, like the # of blocks needed to make a valid config. You can probably, save your IPC config, then just dump this config from a 2024 XLT into your IPC module and the DTC should go away:
Finally, once the DTC is gone, simply restore your old saved config, this will write all the config blocks you saved restoring your config and leave any new blocks from the 24's config unchanged and satisfying the valid config check.
Ultimately, use the 24' config map from Livnitup for any corrections you may need to make.
Report back here and let us know if this works: save-> load 24' config->restore saved config
PJnc284
Garner, NC
Finally, once the DTC is gone, simply restore your old saved config, this will write all the config blocks you saved restoring your config and leave any new blocks from the 24's config unchanged and satisfying the valid config check. Pm'd Jesse as well to see if he had any ideas.
Well that got rid of the U2101 but gave a U0405. Restored the backup and back to the U2101. I have a 511A Lariat ER so think I'm going to look for a 24 Lariat with similar specs and pull the as built from ford. That should hopefully save me from having to manually change pretty much every block.
Code: U0405 - Invalid Data Received From Cruise Control Module
Additional Fault Symptom :)56):
- Invalid/Incompatible Configuration
Status (-0A):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Instrument Panel Control Module
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Status (-0A):
Ahhhh, yea, didn't know you had a Lariat, just grab a 24' AB from Ford with the same options and throw that onto your IPC and you'll be good.
@PJnc284 - I maintain a list of about 100 VINs (with As-Builts and Window Stickers) across all models and options that I use to double-check my Forscan mods page. DM me if you need a couple for your quest.
PJnc284
Garner, NC
Thanks. I managed to find one on cargurus that was close. I narrowed down the issue to the below 3 addresses. Top entry for each is 2024 AB and bottom is my previous IPC values. Changing any of them results in the incompatible configuration. Now to go poke around livinitup's spreadsheet. edit: looks like all of those are seatbelt related. I already disabled the chime 720-01-01 so not sure if it's related or not.
Ford F-150 Lightning Enabling charge speed on dash. 1760208252636-ci
Good luck. FWIW, your top row Data1-Data3 is consistent with values I see for 24-25 Lariats. And the bottom row is the same as 22-23 Lariats.
Jesse-Infotainment
2024 F150 Lightning Platinum
2101 is due to the lower portion seatbelt config. You can load a complete 24 IPC as build file and write it.. it will clear the 2101..
here is an as build you can use
2024_IPC.ab
PJnc284
Garner, NC
2024_IPC.ab
yeah I managed to find a 24 Lariat online and pulled the as-built from the motorcraft site to load. Problem came when I tried to restore my config as it would restore those 720-12 and 720-13s and kick out that 2101 code. Managed to narrow down the issue to those by manually updating the different blocks. Below is what I ended up changing from the 2024 ab. Some due to Forscan mods , some due to my specific truck config (e.g. power running boards, etc), and others that are above my paygrade. My truck is a 2023 ER Lariat 511A with trailer brake, power running boards and max tow so others trying may require different changes but seems you should be good to restore a backup as long as you change the 720-12 and 720-13 back to match the 2024 as built.
Module AddressData1Data2Data3
2024720-01-010F0A106CF0AE
2024-modified720-01-01078A1004F4C2
7- shutdown timer, 8- glarefreexx0x seatbelt chime
2024720-01-02022F80DB
2024-modified720-01-02020F82BD
xx0x- door ajar2-startup chime
2024720-02-014DE539054EE8
2024-modified720-02-014DE5BF354E9E
2024720-03-01E0000000000B
2024-modified720-03-01E50000000010
2024720-04-01200001020150
2024-modified720-04-01240001020154
2024720-07-0184018AA0401E
2024-modified720-07-0184098AA02006
2- quickboot
2024720-09-01706215549905
2024-modified720-09-01F06215D49905
2024720-10-011B080021007C
2024-modified720-10-011B080023007E
3- glarefree
2024720-11-01C42404001035
2024-modified720-11-01C5240420286E
2024720-11-02008000BA
2024-modified720-11-0204030041
2024720-12-0122C00000001C
2024-modified720-12-012AC000000024
2024720-12-02200080DB
2024-modified720-12-020000003B
digitaldad
ABQ
'23 Lariat ER MaxTow
Luvin' the nerd stuff!
Question: if you upgrade the IPC on a '23, to '24 as this example shows, does one then need to always follow (remember, going forward) the specific/if any '24 guidance on future IPC changes when performing a different mod (within that module)?
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Yes, if you are using 24' firmware in your IPC then your module configuration has to follow the 24' config scheme.
