flyct
- First Name
- Jerry
- Sep 28, 2023
- South Florida
- 2024 Ford Lightning Platinum 2024 F-450 Platinum & 2-2023 Tesla Model Ys
- Occupation
- Blissfully Retired
Recently in the last few weeks my iPhone had been acting weird when trying to use it to open the Truck door.
When using only either my or my wife's iPhone:
With the FOB in my pocket everything works as expected.
So far I've done the following with no changes:
Some background.
A few weeks ago the mobile tech replaced the door keypad. In doing so he totally removed the driver door panel. I don't remember if PaaK worked to unlock the door after that visit. I know it was working fine immediately after taking ownership but don't remember when it began to fail.
It is like then external proximity sensor is not sensing the phone nut the internal sensor is sensing it fine. I am thinking that perhaps an sensor or antenna in the door panel was left unplugged and that is what is causing the truck to not sense the phone when near the driver door.
Has anyone had similar issue and does anyone have any thoughts?
- When I walk up to the truck the truck doesn't sense the phone. The "Welcome Lights" don't come on. I can use the keypad to unlock the door fine.
- After entering the truck the truck starts fine with the START button.
- After turning the tuck OFF and walking away it does NOT activate Walk Away Lock.
- When I walk up to the truck the truck the "Welcome Lights" don't come on.
- After turning the truck OFF and walking away, it activates Walk Away Lock
- Deleted my Phone as a Key and repaired it
- Disconnected the 12 v battery for several minutes and reconnected it
- Had me delete the phone from Ford Pass and pair again.
- Had me verify Bluetooth connection
- Had me verify Location Services was "Always ON" for the Ford Pass APP
- Had me log off and ON the Ford Pass APP
- Had me verify that the correct F-150 was connected via Bluetooth
- Had me verify that I had multiple cellular signal bars on my phone
- Had me verify the the FOB worked as intended, which it does.
- Had me move my Apple Watch away so it wouldn't be Bluetooth paired with my phone
- Had me power cycle my phone
- Had me turn Bluetooth off and on and verify the Truck was connected
Some background.
