Jseis
- Jul 22, 2023
- Washington
- July 2021 SR MME, July 2023, Lightning Lariat
- Occupation
- Retired
I think we agree..,modern ICE AWD cars efficiency is tied to effective combustion and heat management critical with higher compression/operating temperatures/exhaust temps and engine/transaxles units means more nearby heat sinks, thus heat damaged gear oils.All the published specs show it at 9.61:1. But I'm not sure I follow you on the heat thing. What does engine heat have to do with axle gear temperature? I would venture to say that the electric motor gear oil will get hotter than the differential on an ICE because the case is also housing the motor, whereas on an ICE truck the differential is separate, and it catches a lot of airflow.
BEV motor-transaxle units don’t generate anywhere near the heat that BEVs do, thus their transaxle gear oils have a ”cooler” environment. I’m not saying they don’t generate heat, but nothing like a BEV.
