To recap:
2025 Platinum Build date 2/25 (likely Job 1) has sticky drive modes
2025 Flash Build date 6/25 (likely Job 2) does not.
We're gonna need more data :)
See later posts. The behavior above is likely explained by a 4-hour timer,
shoopg
Garrison
Utah, United States
www.lightningretrofit.com
'22 F150 Lightning Pro | '21 Polestar 2 | '18 Charger Scat Pack | '98 Ford F250
Cloud Engineer
To recap:
I have read that this was a bug in early 2025s and should be “fixed” with updates.
Is the bug that it works?! Our very limited data shows an early 2025 has it and a later 25 does not 🤷‍♂️. I can't imagine this would be a trim thing.
I haven’t read the whole thread but the first post here says it is sticky up to 4 hours when truck is turned off, then reverts.
Wonder if that explains the behavior @MDErnst and @WXman see.
MDErnst
Colorado
2025 F150 Lightning Platinum
Could be. I have to admit I haven't paid close attention to it to know if it only sticks temporarily or if it reverts back after 4+ hours off. I normally leave it in NORMAL mode.
I will try to remember to check this and report back.
WXman
Central Kentucky
2025 F-150 Lightning Flash
Meteorology/Transportation
On mine, a simple 4 minute walk into the gas station to grab a soda is all it takes. EVERY start of the truck reverts back to "Normal" drive mode.
The only time it really annoys me is when I'm towing. I would MUCH prefer that it stay in Tow/Haul mode until I select something different.
21st Century Truck
Martin
Haha... same here.
Effonefiddy Lightning
Alfred
I got some questions about FORscan.
I haven't paid a lot of attention to the FORscan threads.But where do I get it? Do I need a laptop? Can I use my phone? What do I need to have this? And how much does it cost?
digitaldad
ABQ
'23 Lariat ER MaxTow
Here's a quick summary - https://www.ford-trucks.com/article...u-use-it-to-customize-features-and-functions/
1. Forscan.org
2. Yes, laptop for configuration changes/programming
3. There is a Forscan Lite (for phones) but not for programming - https://forscan.org/comparsion.html
4. Laptop with windows, bluetooth or hard-wired ELM/OBD2 adapter, FORScan software
5. Software can be had for free (2-month license registration/renewal process) for programming...but a yearly license fee of $20 bucks for more advanced module features.
chriserx
Louisiana
To recap:
2025 Flash Build Date 4/25 VIN suggests Job 2
Drive Mode stays the same across restarts, haven't tested up to 4 hours but it feels about right. Coming back to the truck, say next day, it pops up a brief message asking if I want to switch back to Sport.
Besides post #1 in this thread, also read post #2. There are links to equipment, software, tutorials, etc.
sfbabdi
Note: has issue that puddle lights get disabled.
Remove "Full view not available" message on reverse camera screen while in motion (source)
APIM 7D0-02-02 xxx* xxxx xx-- If 0 change to 1, if 2 change to 3, if 4 change to 5, if 6 change to 7.
Note: reboot APIM after the change. See post 2 below for how to reboot a module.
luebri
Neenah, WI
I wanted to pop in here and just say THANK YOU to everyone that contributed to this thread. I finally spent some time implementing a few items and am really enjoying the improvements I've been able to make so far!
1) Enabled Walk-Away lock toggle so I can turn off the "feature" off (that was inexplicably forced on)
2) Enabled Glare-Free High Beams - Loving this feature, such a better chance of seeing all those roaming deer eager to play a game of frogger.
3) Fix Small 360 degree camera view - The used truck I bought had this issue. Avoided a likely billable service trip to resolve.
4) Enable Silent Mode Toggle - Haven't used yet, but definitely could have used it previously.
bc1
McPherson, KS
Hello guys. Guess I need to do this for the glare free headlights and the other 3 mentioned in post above.
My question is regarding the odb dongle. The odblink ex is 60 bux and the vgate vlinker fs odb2 is 30 bux. Just wondering if the 60 buck one has any advantages that makes it worth 30 more bux over the other one? Thanks.
