- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 F-150 LIGHTNING, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
So maybe a sensor in the stability control run amok? It thinks you are losing traction and tries to shut down?The coolant was a little low, but still visible in the reservoir. I topped it off. Cooling should be a closed system, so I never like seeing anything low.
Service Advance Track sometimes will pop up, then go away so that might be an initial/primary failure.
I had a similar concern about loose connector, but it seems strange that a power reset would solve that. It's very strange and removing the confidence I had going in to the EV world.
I'll have to get it to the dealer. I *hate* having anything I can't solve myself. I like the truck a lot, but if this is what EV ownership looks like this thing might be up for sale soon.
If you don't see any obvious wiring loose or a damaged sensor, just have to hook it up to a Ford diagnostic computer...did you call Ford BEV team to ask about it?
Maybe they could help.
Do you have an extended warranty or are you still within the 3yr 36k mi period?
Yes, I feel the same way, it kind of worries me owning an electronic beast with obtuse warning messages that don't tell us exactly what is going on.
These EVs and many other newer vehicles are computers with wheels and so many electronic things that could malfunction hard for the owner to DIY without diagnostic tools.
Good luck.
