OMO7
23 Lightning
I did the Glare Free, global windows, and 50/50 cam. They all worked originally.
Not sure how long after, but the option the choose glare free is no longer there and only auto high beams is available, but when my lights come on they're still the green auto from glare free and it looks like it's working. The global windows don't seem to work. 50/50 cam works without issue.
Any ideas? I have the AB files.
chriserx
Louisiana
Pure guess, double check the APIM mods, I'd assume that the flags that show/hide the toggles are located there. Can also reboot the APIM and check. Also cross check the changes made with the other mods to make sure you didn't revert anything when making those.
OMO7
23 Lightning
I'll double check. Just found it odd that they all worked originally.
mmarchand
Matt
I definitely need to speed up the frunk opening/closing speed. I often skip using it because it's so slow. I missed what needs to be changed in ForeScan to make this happen. Where do I access the speed and how do I change it?
It was mentioned a couple pages back. Be careful.
mmarchand
Matt
i did see it a couple pages back, there’s where I found out about it. Just wasn’t sure where to change the setting. I’ve only used as built but I guess it’s just in the Easy mode?
I saw your concern posted earlier too, when you say be careful here are you talking about possible extra stress on the mechanism and possibly the pinch sensor not working? Has this been substantiated or still just a working theory?
bc1
McPherson, KS
Good Morning. Happy New Years. On my new 2025 Flash, I'd like to add a cd/dvd player. I have one that plugs into a computer with the rectangular USB-A plug. There is a port just below the sync screen next to a USB-C port. However when I plug it in it says it is for charging only. The manual says something about a place on the top line of the sync screen that it can be changed but I can't find anything. Manual says that port will recognize a jump drive with music and I understand it is looking for .wav files.
Have a different CD player with a headphone plug but no headphone type plug input anywhere on the vehicle. Most of the adapters on Amazon are one way going from usb-c to headphone and not the direction I need going from the player to the usb-c plug. Tried a bluetooth transmitter plugged into the cd player but couldn't get it to connect.
I am wondering if there is a Forscan change for that USB-A charge port to take music that can be made or if there is another alternative or recommended player? Thanks.
I've been looking on Amazon for a CD player that will plug in somewhere but don't really want to invest a fortune for an occasional CD.
Nothing in Forscan I have seen that changes that type of functionality. Your best bet is to rip your CDs to a USB drive and put it the USB-A port under the Sync screen. Search for "USB Fit flash drive". They are very low profile. In Sync, choose the Media App and you can play your songs with many options.
Also see this recent thread.
rathman44
Santa Maria, CA
2025 Lariat
In regards to "IPC Quick Boot"...on Saturday, I tried both:
IPC 720-07-01 xxxx xxxx 2xxx
IPC 720-07-01 xxxx xxxx 0xxx
No changes that I can see, looks stock/default (4xxx). I did reboot IPC modules after each attempt.
Same here. I tried using the "easy method" too and still have the splash screens. 2024 Pro.
I have had no luck either with my 2025 Lariat. I tried with AB edit, and then later I came back and opened up in Easy mode and it said Splash Screen was "Disabled", but I still get the IPC animation on truck start. Boo.
I've been successful with my other edits: Glare Free (truck needed to sit a while before update was reflected, not just some immediate restarts), Euro seat belt alert, disabled seat belt reminder, but this one has remained elusive so far.
bc1
McPherson, KS
Quick question. Does Silent mode/Dark mode cited at post #24 on page 2 make the truck go completely dark inside and out? Without having to throw a blanket or towel over the dash and sync screen.
We have occasions to go out to look at the stars or go to local night events such as fireworks shows and it's annoying to us and others parked around to pull in and wait for tail lights, interior lights, but we'd still like to play the radidio and/or have the heat or A/C on when doing so sometimes in the dead of winter or summer.
It only works when the truck is off. Think parked in a campground and you unlock the the truck to get something out. Opening doors keeps lights off. Then when you lock it back it won't honk or flash lights.
Once the truck is on, you have to take other measures to turn all those things off.
SpaceEVDriver
Arizona
Here’s a thread with videos of it off and with it on.
https://www.f150lightningforum.com/...for-camping-astrophotography-astronomy.23667/
bc1
McPherson, KS
Thanks. I guess. I just woke up after having this dream, or maybe it was a nightmare, that I was driving a truck with batteries instead of an gas engine. Thought I'd come to the computer for a reality check and have a cup of coffee. I hope nobody else is having this dream. It all started when I fell asleep watching a rerun of Rod Serling's The Twilight Zone. Guess I'll finish my coffee and hope there is a good ending to this story or if I am out in the Twilight Zone somewhere wondering around lost.
xwing
Okeana, OH
2023 F-150 Lightning
I got Forscan just before the holidays and just got a chance to make some changes. Global window open/close was something I enabled. I can press the unlock once then a second time and hold about 3 seconds and the windows go down. I can't get them to go up. I assume its lock and then lock a second time and hold and the only thing that happens is locking. I have rechecked my changes and all looked ok except on the APIM 7D0-09-01 I put the E in the wrong place. I have fixed that and still no joy. I also have enabled GF headlights so my APIM 7D0-09-01 is 6117 CEA8 FABF. What am I missing?
