SYNC-25.2.1.6.5 Resumed/Revised Rollout
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
Anyone else confirm zone lighting. Please. Oh it’s all I need at this point.
After looking at the post again the person may have been referring to a zone lighting option on the truck screen, not in the Ford app. Sorry to get your hopes up.
Jamchampnate
Nate
Utah
Ford lightning 23’ Lariat
Heartbreaking. Remember the good old days years ago when we had it…we didn’t realize how good we had it.
For those getting this - check your Sync version (Settings..General..About Sync). When I got this update last May, Sync updated to Version 25094. Curious if that's still the case or is it even newer like 25211.
Ford F-150 Lightning SYNC-25.2.1.6.5 Resumed/Revised Rollout 1769204657493-l2
Andrewbens
Modesto
Lightning
Mechanic
I noticed I know have walk away lock on my 2023 XLT ER
Ford F-150 Lightning SYNC-25.2.1.6.5 Resumed/Revised Rollout IMG_3655
astrand1
Alex
Studio truck driver
Hopefully this might signal more updates like the APIM to add Tesla SC to maps.
shoopg
Garrison
Utah, United States
www.lightningretrofit.com
'22 F150 Lightning Pro | '21 Polestar 2 | '18 Charger Scat Pack | '98 Ford F250
Cloud Engineer
Looking for anyone with a Pro to confirm if Walk Away Locks works for them. I've done the changes in forscan initially, I've received 3-4 updates mentioning walk away locks and it either shows up or disappears with the updates. This latest one has removed it.
When the toggles were showing I could enable/disable WAL without issue, but the feature never actually worked regardless.
B177y
Olympic Peninsula, WA
Late reply....
I have a Pro SSV and I had the toggle when the truck was new, but WAL never worked. I fiddled with Forscan to see if I could actually get it working, but the consensus was that the Pro trim doesn't have the hardware for it. One of the updates finally removed the toggle from my SYNC screen.
shoopg
Garrison
Utah, United States
Cloud Engineer
Late reply....
Okay cool glad I'm not going crazy. Similar experience here. I suspect that if we did the proximity door handle swap and bcm flash that WAL would work after that but I'm currently exploring adding PaaK to my truck instead.
B177y
Received this update today and it removed my Glare-Free Adaptive Light toggle which was added via FORScan. But not checked if glare free was disabled yet.
My glare free I enabled via ForScan is still working. I have not looked for the toggle as I cant fathom why I would ever turn it off, but when I get a chance I will take a look to see if the toggle went away.
I just noticed that my glare free toggle in my SYNC screen options is now greyed out and toggled to "off", but my glare free mod is still working like normal (lights do their glare free thing and the indicator in the instrument cluster still shows the green headlight with an "A"). I can also toggle through the headlight options with my turn signal stalk and change modes with the rotary dial.
Have either of you checked your Forscan values since noticing this for any changes? Is your glare free still working?
I might try to look through my values and see if there was something changed with this update but I also want to leave it alone since it is still working. The only inconvenience if you can call it that is the SYNC toggle.
B177y
Ha! Thought I was crazy too! Some of the responses on the thread I started also thought I was crazy. I guess Ford does forget to remove various codes from the software for different trims every now and then...
novosilicon
Eugene
TX
2023 F150 Lightning XLT ER
I've been driving more at night and my glare free seems to be working, but switching just feels like it not so smooth as it was. Maybe just phantom feeling.
B177y
Update: This morning I drove the kids to school and checked my settings page...the toggle is back to normal and toggled on...weird. I guess this is just one of those expected Ford/Forscan mod oddities.
novosilicon
Eugene
TX
Just checked, my glare free toggle did not returned itself.
While it works I'm fine but that feelings that something incorrect is slowly boiling me.
Ford F-150 Lightning SYNC-25.2.1.6.5 Resumed/Revised Rollout 1771351690474-3t
teksavy
Ed
Reno, NV
projects.teksavy.com
2022 LIghtning Lariat, 2023 Chevy Bolt EUV Premier, 2024 Chevy Equinox
I updated my truck via FRDS today and finally have the updated SYNC v 25221 as shown below:
I was at 25094 previously.
The part number for the APIM update was PU6T-14G682-NS
Not sure if that helps anyone or not.
-Ed
Ford F-150 Lightning SYNC-25.2.1.6.5 Resumed/Revised Rollout 1771444774382-nq
