Rear Camera Fails
Nolander
Scott
Does anyone else ever experience the rear camera failing to activate when you shift to reverse? From time to time I will turn the truck and and slap it in reverse and the OS is either too busy figuring itself out or something has it jammed up. Often it will finally kick in once I am already moving forward.
Seems like a very prominent safety issue for @Ford Motor Company, one that I have seen recalls for on other vehicles.
chriserx
Louisiana
Unplug the nintendo and plug it back in, if that doesn't work, take the cartridge out and blow on it.
Edit: In case it wasn't clear, disconnect the 12v for a few minutes and reconnect, won't hurt, may help.
NH
2023 Lightning, 2012 Escape hybrid
Yes have been experiencing very same issue but also get message “Camera is unavailable. Please contact your dealership.” Haven’t determined if due to shifter interlock, extreme cold, or as indicated slow boot up of the OS/display. Definitely intermittent issue but more frequent last two months and planning to have dealer check soon at my 70k service. Probably won’t happen for them though.
rdr854
Northern Virginia
put in a report on the NHTSA website. There are several vehicles with rear camera issues and this is a safety standard issue that could cause a recall. You should also contact your service department if this persists as the OEMs look at warranty claims as well.
chriserx
Louisiana
Take a pic when the issue happens with the days newspaper showing the date every time it happens so you have documentation.
rdt7
Bob
2023 F150 Lightning (Lariet - ER)
My rear camera activates when I put the truck in reverse, but it is now pointed down so it's useless when backing up. I've pushed every camera button on the screen to fix it with no luck. Any suggestions? Here's a pic. A little rainy today so it's not very clear. It's look down where the trailer hitch would be if installed.
Ford F-150 Lightning Rear Camera Fails IMG_2195
chriserx
Louisiana
Take a pic, but is it the rear back up view or is it the over bumper view. If it's not the over bumper view you may have to reinstall the camera I'd guess. If it's the latter, would be a software issue.
Wattsgas
MIke
Brinnon, WA
I have this issue occasionally on vehicle startup. I am assuming it is due to the 12 volt battery putting the systems to sleep and taking a bit of time to boot it up. The one thing that irritates me about the camera, is that it is dirty. It gets dirty whenever it rains and you can't see a thing out of it. I have developed the habit of wiping it down before I take off. Helps a bit.
chriserx
Louisiana
I don't know if it's glass or plastic and you definitely wanna get a professional opinion before trying it but wax or rain x may be your solution.
Wattsgas
MIke
Brinnon, WA
I've tried wax and ceramic. Haven't tried rainex. Saw a youtube video that suggested potato starch from potato peals. I've been thinking about making a small cone to set over it, hoping it will break up the air flow. My other cars with rear cameras don't have this issue. I think maybe has to do with air sticking to the lightbar and water dripping down on it. Thank you for the suggestions.
chriserx
Louisiana
Starch would be a surprise. I'd think you'd want something hydrophobic in general, but I mean when you've tried all of the other options, what the hell?
rdt7
Bob
I still haven't been able to fix this problem. I did a soft 12V battery reset (flash lights 5 times.... etc.) Got the signal the battery had been reset but the camera view didn't change. I'm afraid to disconnect the 12V battery based on what I've read on the Forum. Any more suggestions before I take it to a dealer?
Shouldn't have any problem with a 12v reset, just make sure there are no software updates in process. (PULLING THE NEGATIVE TERMINAL)
If you're still in warranty, maybe this is a defective camera they can replace.
You did a BMS reset. That just tells the main computer you have a new battery. Doesn’t reset any other module (your issue may be in the IPMA module ).
Disconnecting the negative post won’t do any harm. I’m curious where you read that here.
DoyouLightning
BK
Charlotte NC
23' lariat ER
Not sure this will work but any time my center screen gets laggy or freezes up. I do the steering wheel reset: while truck is on hold down the far left and right buttons on the steering wheel for about 10 seconds. I believe it's the volume down button on far left and on the right it's the track skip arrow pointing right. The screen will turn off for about 8 seconds and then boot back up. Usually fixes my issues. Hope this will help.
