BluesClues
2022 f150 lightning sr lariat
Yep, just send me a DM with your address and I'll get one shipped Monday.
oh snap, you're making a mount for FitCam + C4 users? OK this was my final step in deciding haha.
I also tinted my front windshield, so that was holding me back too…but knowing I can run the fitcam and the comma together is huge.
Ajzride
Alan
Houston
Eng
if you are concerned about your tint, put one of these under the comma mount:
https://www.amazon.com/Windshield-S...tatic+film+for+dash+cam&qid=1772651873&sr=8-2
I'll say I've pulled my mount off 6 or 8 times and never damaged my tint, but the static films can give you an extra level or protection.
BluesClues
Ajzride
Alan
Houston
Eng
amazing. saved!
re the Fitcam mount, do you have a pic of your C4 setup w/ the fitcam on passenger side?
I don't use the C4 in the truck. But it's the same relocation bracket for both devices. So it will be in the same spot as the pictures I posted with the C3X. Then the C4 will be wherever you decide to put it.
Lake Placid Lightning
2023 Lariat SR w/510A
Civil Engineer
I remember reading a comment you made elsewhere to the effect that you would just place the C4 behind the F150's rear view mirror because you won't be able to see the details on the C4 small screen. I like this idea, but doesn't the driver facing camera on the C4 need to be able to see my eyes/head to make sure I am paying attention (like Blue Cruise does)?
Ajzride
Alan
Houston
Eng
yes, i had forgotten that it is on the side and not the bottom like the C3X. I think someone else pointed that out too.
BluesClues
ah given this, the offset mount probably isn't necessary right? I can just mount directly beneath the fitcam (cuz I never see my fitcam now anyway)
I'll order the lightning coupler in the coming month!
Ajzride
Alan
Houston
Eng
you still want the offset bracket, or your c4 will be all up in the middle of your FCX field of view.
Ajzride
Alan
Houston
Eng
The 6.0 beta has been synced up with sunnypilot master as of 03.04.2026. Since this included some major updates to submodules, we have decided not to push it into bp-6.0-beta, because it could cause a failed upgrade. To move over the new beta, please uninstall and use the following URL:
installer.comma.ai/BluePilotDev/bp-6.0.1-beta
or
bit.ly/bp601beta
ZheWiz
Jack
Central NY State
Database Developer
Thank you for that bitly address. My eyes and fingers appreciate it!! :)
branden
Branden
'22 Lightning Lariat ER
Did about 350 miles in my Lightning with BP 6.0 and was very impressed. Even smoother than 5.0 which I thought was great!
Ajzride
Alan
Houston
Eng
Are you using ford ACC or OP long?
PJnc284
Garner, NC
Since you drive a lot, what model and settings are you using (PC blend high/low, pid gain)
or
bit.ly/bp601beta
Did the BP Portal from 5.0 change? Was just looking at it on 6.0.1 and all I see is the Parameters page which is a pain to navigate.
