Lightning Pro Power Outlet to Generator Inlet Cord Issues
Sullyfamily
Tx
None
Last year I installed a Generac 6854 which is the same as the 6852 but includes the Generator Inlet and a 10' four prong cord. All works well however the 10' cord is just too short. I went to Harbor Freight and bought a 25' cord and now I am getting ground fault errors. I exchanged it for another one thinking it might be faulty and the issue continued. I used a multi meter to check continuety and everything checked out. Does anyone here have a suggestion, or possibly a longer cord they have successfully used? I am not interested in snipping the ground so that is not a possibility.
Thanks!
chriserx
Louisiana
There has been much discussion regarding transfer switches and I forget the term but effectively multiple ground points. I do not know if it applies to your particular setup but it sure sounds like it.
First thing I'd do is check the ground on the 10' for continuity.
Second thing I'd try is putting the 10' inline with the 25' for a test only.
If it works I'd search for similar grounding issues on the forum regarding the issue and see what the permanent solution was, I know I've seen it but since none of it applies to me I didn't retain it.
Note:
I am not an electrician.
I do not have the 9.6kw PPOB.
I do not have any transfer switch as such.
Sullyfamily
Sullyfamily
Tx
None
I actually did both of those suggestions. Both the 10' and the 25' continuity test the same. Connecting them together also produces the ground fault. Puzzling!
25StarWhiteLightning
Midwest
2025 Star White Lightning Lariat
This is not electrical advice but what I did was remove the ground from the cable and it won't produce the ground fault anymore. I snipped off the end, cut and capped the ground, and reinstalled a new cord end. It will now only work with bonded generators and/or my Lightning.
Measure the resistance between each conductor of the 25’ cord with it not connected to anything. If it’s anything less than infinity, the cheap insulation in the cord allows enough leakage to trip the GFCI.
Sullyfamily
Sullyfamily
Tx
None
Doesn't that defeat the purpose of the neutral transfer switch I bought?
Sullyfamily
Sullyfamily
Tx
None
Thanks! That's exactly what it was. I will get a better one tomorrow!
Midwest
Good point. I am using just a generic generator input into a 50Amp breaker.
I did think the Generac transfer boxes did work directly plugged to the truck.
Big guy
2009 Ranger, 2008 Shelby GT, 2013 Ford Edge, 2023 Lightning Lariat SR
can you post a link/info for the RV cord and adaptor you found that worked?
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
I use this one successfully (15’ version). It comes with an inlet box which I needed as well.
https://www.amazon.com/dp/B08RBN16DR?
We are moving to a different home. The new home has a NEMA 10-30R now on a critical loads sub panel for the generator inlet.
Wondering if I should try to use it with an adapter of sorts and stay with whats hooked up? or go with all new system like you used..
If I go with the system you bought…what did you do to it to make it work for your lightning without issues..? TIA
Sullyfamily
Sullyfamily
Tx
None
There are multiple threads on this site discussing the various neutral switching transfer switches. The most popular one is the Generac 6852. Here is the link to the one I installed. Works great!
https://www.f150lightningforum.com/...pro-power-240v-plug.14017/page-12#post-481452
