Home Charging STOPS at 85%
OpenMinded150
Ethan
Northern NY
2023 ER Lariet Lightning
Renewal by Anderson
For the last few weeks my 23 ER lightning with 123,000 miles on it is stopping charging at 85%. I have the settings in the app and the truck set properly and have tried adjusting the charge limits to see if it makes a difference. But no matter what I set it to the app will tell me it’s charged to 100% but the truck stops charging at 85%. Has anyone had this issue or know of any solutions?
Ford F-150 Lightning Home Charging STOPS at 85% IMG_0692
K6CCC
Glendora, Calif.
Your screen capture shows charged to 100%, where are you seeing 85%, and do you have a target charge location for home and if so, what is the target charge?
frautumn
Fred
Northern CA
2022 Ford F-150 Lightning Lariat
This was happening to me awhile ago, it was a bad battery module. Take it to the dealer and they can diagnose and replace on warranty.
EDIT: Another issue when this happens is that it charges very slowly once it reaches a few percent from the max (usually 100%, but in your case 85%), so if you see very slow charging as it approaches 85% it's most likely a bad module.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Since your out of warranty, lets think about something else ... I assume your app shows 100% but you get in the truck and the screen shows 85%, is this correct?
Ford Motor Company
Official Ford Account
F-150 Lightning
For the last few weeks my 23 ER lightning with 123,000 miles on it is stopping charging at 85%. I have the settings in the app and the truck set properly and have tried adjusting the charge limits to see if it makes a difference. But no matter what I set it to the app will tell me it’s charged to 100% but the truck stops charging at 85%. Has anyone had this issue or knkw of any solutions?
Hi Ethan,
First off, 123,000 miles on a '23? That is impressive.
Sorry to hear about the charging hiccup though. That disconnect between the app saying 100% and the truck stopping at 85% is frustrating, especially since you have already done the troubleshooting on the settings side.
I want to get this in front of the team to look into, particularly with that kind of mileage on the odometer. It could be helpful data for us to understand what is happening with the battery management system here.
Could you send me a DM with your VIN and the best email to reach you at? I will get a case started for you.
Sounds like the same symptoms I was having. It is described in SSM 53208.
While your app shows 100%, the 249 mile Range shows about 78% of your ER battery. And I'm guessing when you start your truck the SOC immediately drops to <90%.
Several of us have experienced that and it's a bad cell in one of the 9 battery modules. I was never able to charge past 83%. Currently at dealer awaiting module replacement. I see you're out of warranty (over 100K). Dealer told me it was a $7500 repair. :(
If you have an OBD dongle, you can use the free CarScanner app to look at the HVB module variation (details in post 1 of my thread). Anything over .030 V (or ~2.5%) would likely be considered out of spec and suggest replacement.
The Weatherman
Dean
South Central KY
If your up for it, I would suggest contacted the dude that posts on Out of Soec Renew YouTube channel.
He has replaced Lighting (as well as other brands) batteries. I am sure he could do it for less then the dealer would and seems extremely capable.
Here is a link to his site:
https://www.youtube.com/@OutofSpecRenew
Good Luck.
PS he is or has recently moved from Colorado to NC.
OpenMinded150
OpenMinded150
Ethan
Northern NY
Renewal by Anderson
This is correct.
Rayden
'23 Lightning Lariat ER
Good Luck.
Thanks for finding that link. I knew I'd seen him doing some work on a Lightning, but couldn't remember where it was. I hope I never need to find out, but better for me (in Florida) that he's now in NC, not OR!
