Heated Steering Wheel Retrofit PU-22G06
shoopg
Garrison
Utah, United States
www.lightningretrofit.com
'22 F150 Lightning Pro | '21 Polestar 2 | '18 Charger Scat Pack | '98 Ford F250
Cloud Engineer
I want to do this too. Would you be able to point me to the crimp connector needed for the BCM? Does this pin simply supply constant 12V, or is there any programmed function to it? I don't recall the FORScan programming for HSW involving any changes to the BCM.
As far as I can tell it just supplies a constant 12V with vehicle run. Shouldn't need any programming for it to turn on.
EU2Z-14474-AB - BCM terminal & crimp connections
WT-56816- - more crimp connections
WPT-404 - SCCM connector
Ford F-150 Lightning Heated Steering Wheel Retrofit PU-22G06 1773322995264-r
Ford F-150 Lightning Heated Steering Wheel Retrofit PU-22G06 1773323046889-0q
rio
CT
2016 Chevy Volt, 2023 F150 Lightning Pro
Thanks! Very helpful.
rio
CT
Would you (or anybody) happen to know the direct p/n to the terminal crimp pin if I was to crimp the terminal onto the wire myself?
watts/up
23 Pro SR
rio
CT
mrkwtech
Tampa Bay, FL
peoplenotproperties.com
2023 Platinum
Real Estate
Out of curiosity, has anyone else qualified for this and NOT have the CSP listed via their VIN? I've confirmed build date and assembly plant per the notice for my '23 Platinum, however the dealership says that they can't pull it up for my truck. I also don't see the CSP in my app or on the Ford site, despite me purchasing brand new and it meeting the criteria.
mrkwtech
Tampa Bay, FL
2023 Platinum
Real Estate
OMG LOL, I contacted Ford directly due to the local dealership not being able to help... we discovered that the CSP was actually performed back in 2023 by the dealership that I ultimately purchased from the following year. So now apparently the issue to resolve is that it's not working for some reason. Results of this new info TBD!
tls
New York
2022 Lightning
They've had enough trouble with CSP and recall work being done incorrectly on our trucks they have re-recalled for at least one of the recalls from around then... So not entirely surprising. @Ford Motor Company may be able to help (is Brian still here after the Lightning cancellation?)
Ford Motor Company
Official Ford Account
F-150 Lightning
Hello yes, I am here! @mrkwtech which CSP are you referring to? I'll see what I can find on it.
