GrokTime
Sean
Ithaca, NY
2022 F150 Lightning, Rivian R1S 1st Gen
It is a free option. It is a bracket that screws to the rearview mirror where the FCX would screw to, and then has an arm to move the FCX over 5" towards the passenger side. The FCX is still invisible to the driver (hidden behind the rear-view mirror), but the comma can now be centered. Leaving the FCX at the base of the mirror means mounting the comma low, and having issues with driver monitor, or mounting it to the side and having issues with ping pong.
Thank you. And just so I am clear, the sliding dock itself is identical whether or not you get the FCX bracket?
GrokTime
Sean
Ithaca, NY
Thanks. I just submitted an order form.
I am about to order the Comma.ai itself. Is there a referral program I can use to help anyone out?
Anders
Anders
F150 Lightning Lariat 2022
Tower crane operator
Did you turn on ICBM? It's a beta level feature to let the comma adjust the speed stepping by simulating the steering wheel button presses.
Yes, that was the main issue. I think the sub-settings might be arguing a bit. SSC vision and map seems to work better with only one selected.
Ajzride
Alan
Houston
Eng
only choose one. Combined will cause them to fight each other.
branden
Branden
'22 Lightning Lariat ER
Comma updated the driver monitor software to specifically watch for phones. If you have a phone in your hand, or on a dash mount where it can see the phone, it will trigger the warning and countdown. Several people have had to remount their phones because it was in the comma field of view and it thought they were playing with it.
Is anyone working to improve this? Shouldn't driver monitoring get more lenient as the ADAS improves instead of more strict?
Ajzride
Alan
Houston
Eng
see, you’re using common sense. That is not allowed when lawyers walk into a room.
Free Charging
Atlanta, GA
Tesla Model Y
And when you crack down on attention monitoring ineffectively on an open source project like this, you risk pushing people to forks that remove driver monitoring altogether.
theaustinite
Ben
Will
Bluepilot/Sunnypilot need to be updated to include these changes?
Ford F-150 Lightning Comma AI self driver assistant IMG_3950
Shmoe
2024 F-150 Lightning Lariat, 2025 Rivian R1S, Sold-2020 Tesla Model 3 SR+
Those forks aren't allowed to distribute to the comma 4 via comma.ai .. so it's not some easy point and click thing to get it on to your c4.
Do they even exist? If humans didn't suck, we wouldn't need this stuff.
Alas, you've got people admitting they couldn't hold on to or jiggle the steering wheel for a second and used a wrist weight instead to evade it right here on this thread. There's plenty of corner cases where they plow thru cars because they couldn't be bothered to let the system disable itself properly in an emergency.
Anders
Anders
I have an issue when I try to set the speed like it will with the comma disconnected, it runs wild. I use KM/H, and if I want to jump up lets say 30 km. It will maybe jump up 60-70 above, drop a bit, go up. Then I fight it a bit and some times it will go up 20 and then jump down to a number ending with 5. Eks. Go from 60 to 110, it can go down to 105 or wildly go up to 160. Clicking one time works well, but long click for 10 gets it riled up.
How do I get the log to send to bluepilot?
WilliamRobert
Western Pennsylvania
2022 F-150 Lightning, 2023 Mustang Mach E
happily retired!
Is your predictive speed tuned on? I turned mine off because it would use mile markers, mail boxes, any number along the road. It‘s not a feature worth using.
