- First Name
- Brandon
- Jul 26, 2022
- Tucson, AZ
- 2022 Lightning ER, 2025 XC90 Recharge
While the modules are swappable, keep in mind that you need a way to balance the incoming module with the others. You don't want to just connect everything together until all the voltages are as close as possible (at least I think that's how it works).I am going to go forward this next week with the battery replacement from the salvage one, it has 35k miles on it so it should be good, all I am out is the cost to pick it up and put it in the return if it doesn't work. The first problem was with the battery pack so that I don't think went away.
