tearitupsports
- First Name
- Russell
- Jun 1, 2024
- Houston, TX
- 2023 F-150 Lightning Lariat ER
- Occupation
- Industrial Automation & Controls
I have a PointGuard system, which by itself is an amazing home backup. the 0ms backup time is a real thing and I can go on or off grid without even noticing.
There are 3 options I am working on as far as integration with the truck.
Option #1 is to save the money I spent on my HIS (which luckily was significantly less than most) and get it working together. I think I am close, but haven't quite gotten there yet. I need to relocate the CT meter from the original HIS to the new system.
Option #2 is to use the PointGuard generator input with the pro-power onboard. I have purchased all the materials for this, but need to install it. The nice thing is that the Pointguard will still power automatically, and I can plug the generator in for extra juice, but I can plug and unplug the truck as I desire. For reference I have my whole house on the backup including my 5 ton AC (with a soft starter). It would also allow me to use a portable generator as well if I want for some reason.
Option #3 is to get the Pointguard V2X module. I am hesitant until I exhaust all tries at #1. If I didnt already have a system, it would be a no-brainer. I am talking directly with pointguard and their distributor and the module can be ordered, but has not come in stock yet.
One nice sidenote is that Option 2 will work with both #1 or #3 at the same time for extra power if needed.
My house really only uses 6-7kW max. Right now the Pointguard with 2 batteries would cover 8kW by themselves. The generator input would add 7.2 kW from Pro Power. The truck HIS could add 9.6 kW. The PoingGuard V2X module is capable of 11kW out to AC loads, plus up to another 14kW to charge the home batteries if they are in the same stack.
Once I get this finished up I will post a lot more information in a new thread so people looking into this from scratch can see another better option. For those with HIS already I will see if our hardware can be saved to be used with something else possibly.
