Emergency Frunk Release Activated - lesson in organizing cargo in the frunk
CD4TNF
This is what happens when cargo presses the frunk emergency release button while you're driving. The truck does some warning bleeps and flashes these two screens.
Ford F-150 Lightning Emergency Frunk Release Activated - lesson in organizing cargo in the frunk 1000019079
Ford F-150 Lightning Emergency Frunk Release Activated - lesson in organizing cargo in the frunk 1000019078
Fortunately the frunk does not fly open. It remains closed while driving.
As you can see from the speed, I was on the highway. I took a interchange corner on-ramp and the cargo shifted in the frunk. Apparently enough to press the release button.
I drove another mile or two, enough to get off the highway and pull into a parking lot. Opened the frunk, shifted cargo around so it wouldn't press the button, and continued on. Here's the offending item.
Ford F-150 Lightning Emergency Frunk Release Activated - lesson in organizing cargo in the frunk 1000019091
I do recall folks here 3D printing a cover for the button to prevent this situation.
Lesson: Keep stuff away from the emergency frunk release button. If the button does get pressed while driving, it won't cause a crash, you can still see because the frunk stays closed.
21st Century Truck
Martin
TheBigBezo
Earth
F-150 Lightning Lariat ER
I also had this happen a few times with golf clubs. The 3D printed cover helped as long as it doesn't pop off. I glued mine on to keep it in place.
I printed it at the library, for free.
Has anyone considered unplugging the circuit to the button?
...............cue the risk and liability warnings from the peanut gallery...........
If you aren't able to escape abduction from the Frunk while the fruck is moving, what good is it anyway?
