2023 Ford Lightning not charging
Has anyone experienced this.
  • Total voters
I tried editing original poll, the forum would not hold requested changes because of existing data, so I purge the old poll and recreated it with Yes & No responses limited to only one of the available choices.
You may now submit a new response, prior trend was a unanimous & resounding no.
Adventureboy
@om2005 DCFC has a learning curve.
Are you trying to Plug and Charge? If so, you need to have a valid Blue Oval Network account with a valid credit card attached. The Plug and Charge slider must be active on your Ford App under the Charge Settings tab under Advanced-->Charge Payment and Access.
If not using Blue Oval, you need the app for the charge network and have a valid credit card attached to the app. Have the app open and ready to authorize the charger when you plug in so it doesn't time out.
When you plug in, insert firmly and hold the DCFC gun square to the charge port until you hear the lock mechanism engage. This is a common problem for new Lightning owners.
P-38
2024 Lightning Lariat
Here's your message with corrected grammar:
Until it wouldn’t on there blue oval network
Another fine example of AI... Here it is with corrected grammar but then grammar.
It's hard to tell but they might be having a DCFC issue and not a level 2 issue but it's unclear.
Mike G
N. AL, USA
@Ford Motor Company ...you see what happens when all the OTAs stop and people can't get their vehicles fixed? The bickering starts on the forums...and then there's flame wars and it's all because you stopped sending out OTAs....I think.
Ford F-150 Lightning 2023 Ford Lightning not charging {filename}
Grease Lightning
Johnathan
Albany, Oregon USA
2023 F-150 Lightning XLT
Maybe you are new to the internet, when someone drops their particular issues in with another's, it creates confusion and is rude not to mention disrespectful to the op.
Perhaps you're also unaware of the hypocrisy in your telling me what to do in this thread hmm?
In the future if you do not like what I post, you can add me to your ignore list here and you'll never be bothered with what I have to say ever again.
Or I can continue calling you out?
This is a community to help people, so sharing similar issues is relevant and helpful because the could be a common issues.
This is not a home of your personal narcissistic desire to have it their way. That is the decision of the Mods.
Maybe you should learn to let people post about like topics and let the mods do their job.
The OP was requesting feedback if any one else was having charging issues. They wanted that type of comment, so it is not disrespectful nor confusing. The more people that reply with DCFC issues, resolved or not, the more likely we are to help the OP with his issue.
MaintGrl
Marsha
El Sobrante, Ca
Ok, can we end this and get back to topic at hand . .please!
MaintGrl
Marsha
El Sobrante, Ca
Currently my truck won't DCFC at any location. I have tried 3 different Electrify America locations and 1 Rivian Adventure. My Nissan Ariya DCFC at those locations just fine. I get a red ring light error after about 30 seconds and then the DCFC screen says communication error. I have it at the dealership now waiting for them to work on it. I can Level 2 charge on a 48amp charger at home just fine. Not sure why DCFC is broken but hopefully will find out soon. The dealership I have went to for all my Fords isn't very good with EV and even the most basic issues take multiple weeks. At least they gave me a lightning for a loaner this time.
That has been an issue - something happens with the pin that locks the plug when dc charging from what I read anyway, and I think the locking mechanism may be powered by the 12v system, which as we know has had many various issues.
chriserx
Louisiana
I didn't see anything about you trying L2 at home specifically so I'd first look at bluecharge, disable it and charge using a card or whatever proprietary app is for that charger.
Next I'd try a 12v reset which was likely already done but it only takes a few minutes.
Even though I suspect it wouldn't even apply to L2, try pulling the manual charger release in the frunk.
My 2023 Ford Lightning is not charging for me. I had it towed to the dealership. They put it on their charger and said it was just fine. After having my truck for a week, I picked it up and almost ran out of energy because it wouldn’t charge at any station. I had it towed back in. The same thing happened; they said they did resets and updated the system with no charging problems at the dealership, then sent it back home.
The third time, I ran low on charge, and I was at 100 miles trying to find charging stations that worked—Level 2 and Level 3 stations like Evo and Gravity were a no-go. I took it to a different dealership, and they changed the battery, then sent it home. The truck did the same thing again. I took it back to the dealership, and they called Ford; now they don’t know what to do. The dealership and Ford are confused, but I have 29,000 miles on it, so I can’t get another one. I hate this truck . The dealership took I was lying. Until it wouldn’t on there blue oval network
Are you able to charge L2 at home?
So the dealership charged it DC fast charging?
If it is just L2 (AC charging) then it is likely the on-board charger or a wire connecting the charge port to it.
The Ford dealership should be able to figure that out!
When all else fails, contact the BEV team at FORD: BEV Hotline 1-866-631-3788, or 800-392-3673, 571-831-5352
I believe the 12v system would power the J1772 signals needed to charge L2.
Could you guys STFU and stick to the subject which is a charging problem...how ironic you want to criticise someone for doing exactly what you have now done - fill the thread with irrelevant BS!
Take your fight to direct messages maybe?
explosive0
2024 F-150 Lightning Platinum
Sounds like the same issue I've been dealing with - https://www.f150lightningforum.com/...after-ecg2-25-2-8-5-update-broke-again.32843/
Car's in for the third time since Thanksgiving and this time they've had it for over 10 days. Left us stranded during Thanksgiving and Christmas travel, so no longer taking the Lightning on any trips where we can't make it back home without charging. Dealership tried to gaslight me the first two times that it was a bad DC charger, or I wasn't plugging the charger properly into the charge port. First time they installed a bunch of updates and sent me on my way. Issue reoccurred a week later, and they kept the car for a few days, cleared the codes, told me it was a bad DC charger, and sent me on my way. Issue reoccurred a third time, except this time I wasn't able to AC or DC charge.
I had a decent relationship with the dealership before now, but this has been extremely frustrating and I have voiced my displeasure to the dealership. They blame Ford for not being able to resolve this during the first two visits - apparently Ford makes it difficult for them to get reimbursed for warranty repairs, so they have to go through a set of steps, which include updating modules etc. before they can replace any parts.
They've been trying to figure out what the issue is, ordered/replaced parts that didn't seem to resolve the issue...etc.
I requested a goodwill buyback that Ford denied, so now I've filed a lemon law claim through the DMV, which has finally gotten Ford's attention.
I got a call from Ford two days ago that they'll be sending a Field Service Engineer to take a look at the car, except they do not know when they will be able to schedule one.
It's been an absolute nightmare for a truck with <10k miles.
