Storx
I recently bought my 2022 Ford Lightning Lariat ER w/54k miles (has 2" leveling pucks), it now has 57k and I truly want to fix my front suspension float/bounce. There is a section of my daily commute on a toll road that is concrete which makes the truck bounce a lot and a few times when driving faster it has made me feel almost unsafe. A few times when people were riding with me, they were scared on why the truck was bouncing so much going through that section. I also need to replace the shocks anyways, because the front tires only have 7k on them and are showing abnormal wear and after having my alignment checked at local shop, they informed me the wear on my tires were signs of bad shocks.
I have read so much and debated so much going back and forth between Eibach and Bilstein shock setups, but ultimately i think the Bilstein 6112 give me the best fit for my future needs.
I want a more planted ride, that gets rid of the bounce and possibly some of the body roll in corners. I have read multiple people who went the 6112 route that reported less body roll without upgrading anything else in the front, which seems to be what I'm looking for. I also have been thinking instead of raising the truck to level it out, eventually install something in the rear that gives me the ability to level the truck to the stock front height. I've read multiple people quoting the 2018 F150 front 6112's will work on the rear, but I have yet to find anyone who can prove this.
This is the parts i have found for the upgrade:
Bilstein 21-22 Ford F-150 4WD B8 6112 Series Front Suspension Kit (47-323841) Amazon.com: Bilstein 21-22 Ford F-150 4WD B8 6112 Series Front Suspension Kit (47-323841) : Automotive
Parts some users mentioned using, unsure if needed or if i can re-use the factory top hat.
KYB SM5727 - Mount Kit Amazon.com: KYB SM5727 - Mount Kit : Automotive
These are the Bilstein 6112's mentioned in multiple threads for rear's, but found no proof of anyone trying them.
Bilstein 15-20 Ford F-150 4WD B8 6112 Series Front Suspension Kit (47-310995) Amazon.com: Bilstein Suspension Leveling Kit, B8 6112 Series, Springs/Shocks/Snap Rings : Automotive
I plan to purchase everything during prime week, so wanted to get some input from everyone to assure i have everything i will need. I have installed coilovers in the past on cars, but this would be my first time on a truck. I do have a high lift jack, plan to purchase higher weight rating jack stands over the holiday weekend from harbor freight.
