Bilstein 6112's: Is this the best route for my needs?
Storx
2022 Ford Lightning Lariat ER, 2022 Tesla Model S, 2017 Tesla Model 3
I recently bought my 2022 Ford Lightning Lariat ER w/54k miles (has 2" leveling pucks), it now has 57k and I truly want to fix my front suspension float/bounce. There is a section of my daily commute on a toll road that is concrete which makes the truck bounce a lot and a few times when driving faster it has made me feel almost unsafe. A few times when people were riding with me, they were scared on why the truck was bouncing so much going through that section. I also need to replace the shocks anyways, because the front tires only have 7k on them and are showing abnormal wear and after having my alignment checked at local shop, they informed me the wear on my tires were signs of bad shocks.
I have read so much and debated so much going back and forth between Eibach and Bilstein shock setups, but ultimately i think the Bilstein 6112 give me the best fit for my future needs.
I want a more planted ride, that gets rid of the bounce and possibly some of the body roll in corners. I have read multiple people who went the 6112 route that reported less body roll without upgrading anything else in the front, which seems to be what I'm looking for. I also have been thinking instead of raising the truck to level it out, eventually install something in the rear that gives me the ability to level the truck to the stock front height. I've read multiple people quoting the 2018 F150 front 6112's will work on the rear, but I have yet to find anyone who can prove this.
This is the parts i have found for the upgrade:
Bilstein 21-22 Ford F-150 4WD B8 6112 Series Front Suspension Kit (47-323841) Amazon.com: Bilstein 21-22 Ford F-150 4WD B8 6112 Series Front Suspension Kit (47-323841) : Automotive
Parts some users mentioned using, unsure if needed or if i can re-use the factory top hat.
KYB SM5727 - Mount Kit Amazon.com: KYB SM5727 - Mount Kit : Automotive
These are the Bilstein 6112's mentioned in multiple threads for rear's, but found no proof of anyone trying them.
Bilstein 15-20 Ford F-150 4WD B8 6112 Series Front Suspension Kit (47-310995) Amazon.com: Bilstein Suspension Leveling Kit, B8 6112 Series, Springs/Shocks/Snap Rings : Automotive
I plan to purchase everything during prime week, so wanted to get some input from everyone to assure i have everything i will need. I have installed coilovers in the past on cars, but this would be my first time on a truck. I do have a high lift jack, plan to purchase higher weight rating jack stands over the holiday weekend from harbor freight.
Ford F-150 Lightning Bilstein 6112's: Is this the best route for my needs? img_5047-jpe
Remove the leveling pucks or retune/realign your front end.
The shocks may help but it's most likely geometry causing your problems.
chuck27p
Chuck
Orange County, CA
F150 Lightning Platinum Black
I am doing this exact same thing. I have pucks and larger tires/wheels and after 2.5 years and alignment issues I am removing the pucks and adding eibach shocks to front. I am also changing the wheels / tires to get better range.
My truck goes in to shop on Monday. Parts are there and waiting for me. I can report back this week to fill you in.
I had 6112s on my Tacoma and it achieved all the goals you are trying to achieve.
The 5100s are also well regarded for firming up the ride. The 6112s are a larger body shock and likely include better valving and components, however it is entirely possible the 5100s would achieve the same goals for SIGNIFICANTLY less money. As till now I have never seen the 5100s and 6112s compared back to back but its likely the 6112s are better for HARD off-road use but that both provide near similar benefits for on-road and mild off-road.
You can get 6112s assembled, if not I believe you need factory too hats.
I am one of the few who believe older front struts can be used in the rear. Be aware though that that is only fitment, spring rate could be quite different.
BabyDoc1012
NC
2023 XLT, 2022 Mustang Mach 1, 2021 Expedition
Storx
Storx
Thank you in advance for the information. I was heavily leaning that way also, but i read a post where someone replaced the front struts in their lightning with eibach's and then lift/leveled it and reported a new bouncy issue in their ride. They later switched to the Bilstein 6112's in the front with a perch relocation kit for the OEM rears leveling the truck via dropping the rear and they claimed the ride was far superior afterwards with the bounce issue completely gone.
The commenter above may be right, the act of raising the front of the truck up to "level" it might be changing the geometry of the suspension, making it favorable for the bounciness issue to show.
Keep us posted. i have not 100% made up my mind yet.
Storx
Storx
It makes sense honestly, a typical gas ICE F150, the front of the truck has most of the weight when its unloaded. So the front suspension is seeing weight levels very similar to the fronts of the Lightning by axle weights i read online. So since the lightning is nearly 50/50 weight distribution, i would assume the fronts from whatever the correct year truck is for the rears should be within spec unloaded. The only part I'm unaware of is how they would take towing loads. This is the unknown I'm slightly concerned about and thinking of possibly going the route of a perch relocation kit to drop the rears to level the truck out to the OEM front height instead of 6112's in the rear to maintain the stock spring rates.
MichaelCA
I had the 6112 done a couple months back.
What I've noticed:
- Truck barely dips/rise during hard accel/braking.
- Floatyness is gone on bumps
- Ride is actually softer at higher speeds if you like driving fast due to the digressive shocks.
- Ride overall is "harsher" and less cushiony but still soft. If the stock Lighting was a 10 in soft/cushyness. The Bilsteins are more like a 7. My ideal would've been a 8.
Richard
Schertz, TX
2018 Lariat F-150 5.0 Ruby Red, 2025 Lariat Lightning Anti-Matter Blue
Network Security
What I've noticed:
Can you provide more detail on what you did here? What snap ring level did you set to and what height did you gain, if any? Also, did you do the rears as well?
tls
New York
2022 Lightning
You guys who are "levelling" your trucks because when the box is empty, the rear sits higher than the front - what happens at max payload? This has never made sense to me.
Richard
Schertz, TX
Network Security
In my case I am looking for a less floaty and porpoise like ride. I did raise my 2018 with 6112's but I also lifted the rear to maintain rake. I have no intention of lifting the lightning just want a more controlled and planted ride.
MrH42
Cincinnati, OH
2023 Lariat ER, 2024 Miata
Putting springs and dampers designed for a gas F-150 on a Lightning is a terrible idea all around.
Remove the 2" lift, get an alignment, and replace the OEM shocks if they're worn out.
MichaelCA
Setting 5. I think it gained about 1-1.5 inches or so. Theres a couple other threads here on this forum that did the same. I still have a bit of rake.
I did not do the rears. I also had it installed with the KYB kit but it is doable if you/technician choose to reuses the old top from the OEM unit.
S. E. Louisiana
Auto tech
I'd like to level mine but there's a few things that stop me, namely screwing up suspension geometry. One of my career specialties is suspension and alignment and the things I've seen over the last 40+ years makes me SMH.
Second reason why I won't level is the dynamic headlights. A level will mess that up, sure they'll still operate but not at the oem calibrated specs not to mention blinding oncoming traffic.
Lastly, blue cruise 1.4> which is also calibrated on many things including ride height, a level can cause issues with that as well.
A true lift kit would be a better choice if they make one for this model.
The tremor is just the factory suspension set ar a higher ried height and the only difference i know of is the upper control arms. The factory suspension should handle a reasonable increase in ride height just fine.
The headlights only go side to side and the up and down aim can be done by the manual adjusters. No worry about headlight aim.
The bluecruise system can be recalibrate and a front 2" level only changes the camera angle by about 0.8 degrees. Or similar to putting a heavy load in the bed.
