theUNSTABLE
Ryan
github.com
Cyber Engineer
Disable backup beeper. This also disables the low-speed pedestrian noise, so please be careful with this one. These noises are federally mandated, and you will be ridin' dirty without them. You'll need to install the megaohm speaker delete kit
Whats strange about this is I know its federally mandated. I have the backup beeper that is annoying, but whatever I'll keep it that's fine - its a safety thing, I don't touch those.
However, I have yet to ever hear my "low-speed" pedestrian noise. Haven't done any mods, I've just never heard it, and I've tried to hear it many times. Creeping around buildings with windows down. I just thought I might not have one. I've Never received a warning or anything about it. I sneak up on people all the time unintentionally.
I've even had people drive my truck slowly by me, never heard a thing.
Does anyone have a video or clip of what its supposed to sound like because the only noise I hear is the noise of the motors.
Edit: Found some clips of the Powerboost - Is it the same sound? If it is close or similar, I do not have that noise - I only have the reverse beep. I wonder if the speaker thing is broken.
Maxx
I have problem hearing that as well while I am in the truck. Never had someone else drive it to test it.
And I fully agree on safety noises. The truck is big and I have had to drive it in noisy places with a lot of people walking around. Even reducing the pedestrian and backup noise is not a good idea. I wish I had a manual way to temporarily increase the noise in some of those occasions when I was backing up and people didn't seem to notice or care.
Maxx
It’s called the horn! ?
That may scare the crap out of nice people in front when I am backing up.
I am thinking to use retractable accessories for those in the back that ignore my gentle backup sound.
Ford F-150 Lightning Disabling F-150 Lightning's Beeps, Dings, Chimes, Honks, Bings, Bongs, and Dongs 1706637533599
BennyTheBeaver
2023 Lightning XLT ER
I have blocked every notification just by installing my own speakers and amp. If you don't use a load resistor in-line between the head unit and some aftermarket amps it disables all system sounds.
Henry Ford
I'd pay top dollar to get adaptive cruise off my tail about "keep hands on wheel". BTW my hand is on the wheel; just that Ford wants you to shake your wheel every 15 seconds. Almost not worth using it on non-blue cruise supported highway's.
Stop steering and start resting. The weight of your hand on the 3:00 position of the steering wheel will eliminate the message. The same applies to the opposite side of the wheel if using your left hand is preferable. You'll teld to be on the left side of the lane though.
VAF84
Central Texas
2024 Sierra EV Denali
Consultant
I’m driving two hours of straight highway, seven days a week, with an occasional 20 hour trip sprinkled in; wouldn’t be a big deal otherwise. I rest by driving with my hand resting on my leg while fingers lightly touch the wheel. While I appreciate your suggestion, it’s not a comfortable position for me for this and other reasons.
Luckily, a one pound weight arrived this week and fixed my problem.
Realtruck
Diamond Sponsor
Realtruck
2022 Ford F-150 Lightning
If you're like me, you'll agree that a stock F150 Lightning has too way too many audible warnings. This thread catalogs the different methods I've used to turn them off, sorted by overall annoyingness. Hopefully it's useful to someone!
Note that many of these noises are federally mandated, and/or genuinely important for safety. Please use good judgement when modifying your vehicle.
Things I've done:
  • Disable frunk beep. This requires unplugging the frunk speaker. www.youtube.com/watch?v=UdWVnZ5vNgM
  • Disable backup beeper. This also disables the low-speed pedestrian noise, so please be careful with this one. These noises are federally mandated, and you will be ridin' dirty without them. You'll need to install the megaohm speaker delete kit: https://www.megaohmmotorsports.com/product/ford-psbk-ece
  • Disable key-in chime. FORSCAN Code IPC 720-02-01 xx*x xxxx xx-- (subtract 8 from current value (if E change to 6))
  • Disable triple chime on vehicle startup. FORSCAN Code IPC 720-01-02 xxxx x2xx
  • Disable door ajar chime. FORSCAN Code IPC 720-01-02 xx0x xxxx
  • Disable seatbelt chimes. This can be done via a series of button presses and seatbelt clicks. Again, please do not ride dirty. See here: www.youtube.com/watch?v=QcMErUaI3Cg
  • Disable "check rear seats" warning. This can be done via the touchscreen: Settings > Vehicle > Rear Occupant Alert
  • BONUS: IPC quick boot. This disables the annoying (albeit inaudible) Ford advertisement that takes over your screen when the vehicle boots. IPC 720-07-01 xxxx xxxx 2xxx
Things I haven't done, but are theoretically possible:
  • Disable double honk if you get out of the truck while it's running and bring your key with you. Mine actually never did this so I didn't bother with it. FORSCAN Code BCM 726-41-02 xxx0 xxxx xxxx
  • Disable parking sensors. This can be done via the touchscreen, although it is a useful tool depending on where you park. One of the few dings that I left on.
  • Disable power liftgate chime. I don't have a power liftgate, so I skipped it.
Things I still haven't figured out how to do:
  • Disable "Rear sensor blocked" chime (yes, I know when my liftgate is down, Ford!).
  • Disable "No key detected" chime
  • Disable chime on lane keeping cancellation.
  • Disable "transmission is not in park" chime when you open the door without having shifted into park.
  • Disable animation on power down.
I'll update this post as I find solutions to the above noises, or if I discover other chimes that need to be silenced. Again, I hope this is useful to someone-- None of this is new information, but maybe I've saved you some time by not having to search for it.
Thanks for the info!
dww
San Antonio, TX
F150L, Tesla 3P, YP
The forward one sounds like a bad wheel bearing (metallic grinding). It’s most noticeable when it goes away at about 25mph. “Is something broken on my car? What is making that noise? Oh, hmm it just went away.” I’ve been “riding dirty” in my 2018 Tesla for 6 years, because it didn’t come with one. Personally I think it’s more dangerous with the noise because for the driver it is masks noises you might need to know if your about to hit something/someone.
VAF84
Central Texas
Consultant
One pound weight from Amazon for the hand on wheel nagging. I have the same issue. Hand on, and it still beeps. The weight isn't practical if you make a lot of turning in urban areas, but works wonders on longer stretches of road.
spdski
Miko
DFW
2023 Lightning XLT 311A
This is probably corrosion in the connector or the plug has slipped out a bit. A Ford Injector will fit in the connector and solve this issue way cheaper.
Does it matter what year/model injector? From looking online it looks like there are some different plugs, so I want to make sure I get the right fit.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Electrically no, but plug wise, sure. It matters b/c that is the whole beauty to the hack is that it plugs right in. I'd say if you match it by picture online or in an autopart store's catalog you'll be fine. Also, if you're buying it new and it doesn't fit, you'll never "installed" it, so you can take it back.
But again, the beauty is that you can grab one of these free from a junk yard.
astrand1
Alex
Studio truck driver
Things I've done:
You should amend this list to add the option of forscan to disable the “alien” sound and back up sounder as well as the megaohm thing.
