UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
Hey all, I’m officially sold out of the 180 couplers as of today. If you place an order this coming week, they may be delayed the full week lead time. DHL has them estimated to arrive on the 28th, but they generally arrive a lot sooner than stated once they are in Texas (which they have been since Thursday).
Best case, I will have them Monday morning and can ship them then, worst case, I’ll have them Saturday the 28th and I can ship them that day with the fastest method possible that won’t break the bank.
tatanka
Southern California
'22 F150 Lightning Lariat SR
Thank you for the excellent knowledge base in this forum.
I just finished my install of the Comma 4 in my F150 Lightning (2022, Lariat trim). I used the coupler from Uncle Tony and the sliding dock. The comma 4 shipped with the Q4 harness and 2 cables (one short, one long). I used the long cable from the harness to the connector, and the short cable from the connector to the dock. After installing the harness as per Ajzride’s video, and prior to sliding in the Comma, I received the following warning:
“Electrical system drain, Service Required”
The warning persists each time I start the vehicle.
Any suggestions as to the cause and recommended fix? Looking online it looks like I should use a shorter cable, but that may not be specific for my issue.
Ajzride
Alan
Houston
Eng
This just means your 12v battery is on the fritz. The only thing you can really do from the comma standpoint is to set it to power off after being idle for an hour.
tatanka
Southern California
Perfect. Will do.
(I see a 12v battery replacement in my future!)
Thank you again!
Lake Placid Lightning
2023 Lariat SR w/510A
Civil Engineer
I installed bp-6.0.1-beta when initially setting up my C4 last week.
Is there any reason I should install the new BluePilot 6.0 instead of keeping 6.0.1 beta?
Ajzride
Alan
Houston
Eng
The beta won't be getting any more bug fixes.
Currently, the only fix of note in bp-6.0 that is not in the beta is something to remove lock files on boot.
I wouldn't say it is urgent to update, but I would do it when it's convenient.
purplelimo
Horace
2024 Ford Lightning Flash
Hi all,
I just received my C4 and installed with inline coupler and sliding dock, and noticed that when my C4 is removed from dock that A/C does not work. If I unplug the long USB from the Comma harness, then A/C works again.
Has anyone else experience this?
chriserx
Louisiana
Hi all,
Yes, you probably have the coupler backwards. Turn it around and report back. 👍🏼
Reactions: EVO
purplelimo
Horace
This is definitely not the case as I have the coupler hooked up lightning bolt to long cable and comma to short cable.
But just for sh*ts and giggles, I flipped it and saw all the errors light up as well as A/C still not functional.
UncleTony
Tony
That is generally from the connectors not being plugged in all the way. Try rotating the end of the long cable (just the connector, not the entire cable) 180 degrees and plugging it back into the coupler. It generally gives a snap when it seats all the way. If the end breaks off, you’ve gone too far.
purplelimo
Horace
I’ve tried reinserting the cables and I am inserting them such that they give that very satisfying click.
The weird thing about my situation is that everything behaves normally when C4 is docked/installed. No errors from car, A/C works normally. It’s just that for the shorter drives where I leave the C4 at home that A/C is not working.
UncleTony
Tony
It has been a little while since it’s come up. But I recall the 24s having the ac issue specifically. From what I remember it was related to the comma power being plugged in and we later found that it was related to the long comma cable having an issue.
In the situation you leave the c4 at home and have the AC issues, do you also have the errors on the dash and do you have the coupler installed in that scenario?
purplelimo
Horace
Without Comma plugged in, there are no errors and everything seems normal other than A/C doesn’t ever kick on.
I did one other experiment, which is to also unplug just the coupler (and short cable). In this case, I get all the errors!
One thing I haven’t tried is to unplug the OBD2 cable. Maybe I should try this since you mention a power problem?
UncleTony
Tony
It’s not really a power problem. The OBD power comma uses also has can in it and it adds a resistance to the setup from the OBD port. I would try unplugging it and see what it does. The comma will just take a little bit longer to boot. If that fixes the issue, I can suggest a new long cable
