Good thing it's not small and easy to lose.Well today was my first day driving after my Bluecruise trial expired… and… I went ahead and pulled the trigger on the comma four haha. Can’t go back to driving myself!
I just hope I can find my coupler, I bought it back in September and can’t remember where I left it![]()
you can't just lose the precious. That is unacceptable.I just hope I can find my coupler, I bought it back in September and can’t remember where I left it![]()
There should really be a TL: DR post that gets updated with the current working status etc.
It should ship with the correct cable if you order an F150 kit. If you just order a Q4 development kit you will need the long cable.So I ordered a Comma Four, and I'm about to pull the trigger on the coupler. Is there anything else I should get to make this a better experience? I've heard occasional mentions of longer cables, but I'm having trouble finding an authoritative answer. I want to make sure I have everything I need when the Comma finally ships.
You may have to get your own cable but I'd try the stock cable first, if you absolutely want to do it first go, you could buy another ?thunderbolt? cable, and return it if you don't need it. Took quite a bit of plugging and unplugging and turning but the stock cable eventually worked fine for me.So I ordered a Comma Four, and I'm about to pull the trigger on the coupler. Is there anything else I should get to make this a better experience? I've heard occasional mentions of longer cables, but I'm having trouble finding an authoritative answer. I want to make sure I have everything I need when the Comma finally ships.
A thunderbolt cable is not guaranteed to work. Like USB C there are different generations of cables. Look for a USB- 3.2 gen2 cable.You may have to get your own cable but I'd try the stock cable first, if you absolutely want to do it first go, you could buy another ?thunderbolt? cable, and return it if you don't need it. Took quite a bit of plugging and unplugging and turning but the stock cable eventually worked fine for me.
it Should come with a long cable. You can buy one to be safe but the one you linked is not a gen2 cableI chose the f150 when ordering, says it comes with the q4 harness, and the comma four comes with a 2ft OBD-C in the box. Thats all we need? Dont we need a longer usb c to go from under the dash to above the mirror, or am I mistaken?
I was planning to buy this Cable Matters 8ft USB 3.2 TB4 cable.
yeah, i was unsure hence surrounding it by ??A thunderbolt cable is not guaranteed to work. Like USB C there are different generations of cables. Look for a USB- 3.2 gen2 cable.
