UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
if I may ask, is your Rivian ok? :)
Haha, it is. It met the dealership again a little sooner than expected. A change of plans puts me further away from a service center than I am comfortable with and we got a 30 foot travel trailer that required us to stop every 1-1.5 hours and made life kind of miserable while towing.
It was a good SUV most of the time, just felt a little under cooked overall.
mattbrac3
Matthew
Ramona, CA
25’ Lightning Lariat in Antimatter Blue Metallic
Local Pig
Hey everyone, I just recently installed the Comma 4 with Bluepilot 6.0 (non beta) in my 25 Lightning Lariat with the Bluepilot Lightning adapter, and everything was working fine. I manually selected the 23 Lighting from the menu as it could not auto-fingerprint. When it starts up now, it is throwing errors on the dash, and the comma says variant not detected on the comma. Any ideas? If I reboot it a few times, it starts working again, but then after restarting the truck, it's back to not working.
UncleTony
Tony
If it didn’t auto fingerprint, there is a bad connection somewhere. Try rotating the connections 360 and reseating them, make sure the lightning bolt is on the truck side.
mattbrac3
Matthew
Ramona, CA
Local Pig
So you’re thinking it should auto fingerprint? And you mean the lightning bolt back to the can bus correct?
UncleTony
Tony
Just realized you have a 25. It may not. But the rest is still consistent with a bad connection.
mattbrac3
Matthew
Ramona, CA
Local Pig
So, I swapped the lightning coupler, manually selected the truck again, and it now says "dashcam mode," unrecognized vehicle, so I am guessing there's a bad connection somewhere. Is there a way to determine if it's the coupler? I have the dock, so there should be a coupler on there, right?
I removed the coupler, and I only get the "service vehicle soon" and the wrench message. The comma works fine. So I am guessing the coupler is bad?
EDIT: Well, I feel like a bit of a silly man. By happenstance, I did some digging and discovered that the coupler needed to go on the side closer to the comma on the windshield, not on the CAN bus side. I moved the coupler, and viola, no errors, and startup was super fast.
UncleTony
Tony
It can go on either side, but if it’s working it’s working.
The comma supplied 12ft has weird connector tolerances that can make it finicky.
mattbrac3
Matthew
Ramona, CA
Local Pig
Appreciate your help!
mattbrac3
Matthew
Ramona, CA
Local Pig
Does anyone know how to recalibrate the face detection? Currently, the comma believes I am looking straight at it rather than toward the road, and reminds me to pay attention when I am looking straight.
Shmoe
The only solid way I know do to this is to flatline the comma.. tap the screen while the loading screen is showing and factory reset/re flash bluepilot.
Willebrew
Will
Dallas Texas & Denver Colorado
Rivian R1T Pre-Order | Lightning Lariat ER Owner
Software Developer & CEO - ADAS research and development for fun
What version of openpilot are you running? The driver monitoring model was recently updated to be much more sensitive following a lawsuit against the company: https://unicourt.com/case/pc-db5-casegu14ab365a0c95-2364221
Shmoe
Ajzride
Alan
Houston
Eng
We are working to try and get the DM fix merged into bluepilot. It's not just a single file to copy, it's an entire submodule to update, and that submodule breaks other modules if they are not updated along with it.
mattbrac3
Matthew
Ramona, CA
Local Pig
So will the update be pushed out? Sorry I’m new to this comma thing.
HunterHan
Curt
New York
2024 Ford Lightning Lariat ER
Hey everyone, I just recently installed the Comma 4 in my 25 Lightning Lariat with the Bluepilot Lightning adapter, and everything was working fine. I manually selected the 23 Lighting from the menu as it could not auto-fingerprint. When it starts up now, it is throwing errors on the dash, and the comma says variant not detected on the comma. Any ideas? If I reboot it a few times, it starts working again, but then after restarting the truck, it's back to not working.
What Bluepilot are you running? 6.0?
