Compressor surging while running AC + DCFC??
ctuan13
Chuck
Pittsburgh, PA
TL; DR: AC compressor audibly surging while DCFC, stops when cabin HVAC is turned off. AC outputs cold air.
Hi All,
I'm currently traveling and towing my teardrop trailer cross-country like I have for the past two summers.
Its currently scorching where I am. I just passed through Colorado and I'm now in Utah. Temps around 104°F.
I first noticed at the last DCFC stop that I could hear the compressor spooling up sound and the vibration in the floor, followed by a spool down (all within 1 second) and this continued, the entire time I was charging. Ive never experience this before, but there are no fault indications and the charging proceeded normally if maybe slightly slower than max speed.
At my next stop, where I am now, the temps are the same outside and I noticed the same symptom. I then got the idea to try shutting off the AC in the truck and the surging stopped. AC has been blowing cold the entire time.
Has anyone else experience this? Is this just an extreme heat thing?
Shmoe
Hi All,
Yes, the system is cooling your battery so it avoid damage while dcfc.
Edit: should've finished reading.. i've never heard it spinning up and down like that.
JayF
Jay
Tacoma, WA
jay.jvf.cc
2023 F150 Lightning Lariat SR
Open Source Developer
Take it to the dealer. Cooling system should be covered under EV warranty. Get a video of what's happening. I've had a similar thing here: https://www.f150lightningforum.com/...irst-several-minutes-of-truck-being-on.37228/ and they identified a sticky valve using a combo of my video and the printout of the resolution from Kevin's (Maine Lightning Owner) thread. If anything it sounds like it'll be easier to replicate on yours than mine.
Good luck!
ctuan13
ctuan13
Chuck
Pittsburgh, PA
Yeah I was gonna say, I totally get what you're saying, I'm very familiar with how the HVAC system cools the pack, but this compressor short cycling is something I've never heard before...
ctuan13
ctuan13
Chuck
Pittsburgh, PA
Good luck!
Interesting, yeah I guess it could be that problem. It stopped doing it once the temperature dropped below 97 so I'll try again in the next few days to get a video.
As for the dealer, I won't be able to realistically until I get to my friends place up in Washington, but once there I'll bring it in! Also gonna hook up my autel bi directional scanner and see if I can observe high and low side pressures when it's exhibiting the short cycling behavior.
Thanks for the info!
The vehicle is supposed to cool the pack while DC charging, and that surges the fans. You hear similar when you turn on the vehicle with AC on if you stand outside (also with the Mach-E). Turn off the AC and it immediately stops.
ctuan13
ctuan13
Chuck
Pittsburgh, PA
You're not hearing the compressor, what you're hearing is the electric fans ramping up and down. If you could hear the compressor, you likely wouldn't have any cold air blowing.
That's my best guess without actually hearing a sound bite.
See I thought that at first as well, but I could hear the fans blowing steady outside the truck, but I only heard (and felt) this noise inside the truck (because it blocked out the roaring electric fans) and was very clearly an AC compressor short cycling.
And I guess while still blowing cold, it wasn't ice cold.
ctuan13
ctuan13
Chuck
Pittsburgh, PA
Well guys, it seems to be getting worse, compressor continues to short cycle when DC fast charging and battery temps rise significantly higher than normal. But if cabin HVAC is turned off, the compressor runs constantly while DC charging and temps are lower.
Also cabin AC still seems to blow cold when driving at least up to around 100°F.
At this point I just need to make it to my friends place in Washington (currently in Idaho), because I'm towing my camper and can't just abandon my truck at some dealership down here. I haven't even had time to run my own diagnostics or check for a refrigerant leak 😬
ctuan13
ctuan13
Chuck
Pittsburgh, PA
Does your 2022 Lightning have the 'Max Tow' option?
Yes it does. From my understanding and according to the shop manual there are two distinct, divorced refrigerant loops, one for the battery and one for the cab. But what I'm not super clear on is is there one compressor or two?
Max Trailer Tow System: Cabin cooling diagram
Ford F-150 Lightning Compressor surging while running AC + DCFC?? 1782052982342-uz
Ford F-150 Lightning Compressor surging while running AC + DCFC?? 1782053049698-zv
Standard Trailer Tow System: Cabin Cooling diagram
Ford F-150 Lightning Compressor surging while running AC + DCFC?? 1782052907570-y9
Ford F-150 Lightning Compressor surging while running AC + DCFC?? 1782052887398-o8
The chiller module cooling the HVB coolant
Ford F-150 Lightning Compressor surging while running AC + DCFC?? 1782053176354-7x
KahnDawg
Vic
Athens, GA
2024 Ford F-150 Lightning Flash
Carrier of souls
Hi All,
By chance, could this be the active air shutters for the condenser/radiator inlet? I hear something akin to what you described primarily in cold weather operation. I have not observed such behavior in hot weather (DCFC while towing in SC this past weekend, the truck stated the ambient temperature was 102°) and cannot recall the air inlet shutters cycling.
