Curious why some do not use 1 pedal driving.
potato
BC, Canada
2023 F150 Lightning XLT ER
This thread is the equivalent of arguing why your favorite color is the best color.
That's kind of the beauty of the Lightning implementation. Both the 1PD and 2PD are so seamless it isn't immediately obvious that you're getting maximum regen/efficiency whichever one you use, so fill your boots.
I'm team 2PD myself, but if I did a lot of stop and go traffic that would probably change.
Mmiketa
Virginia, USA
'23 Lightning Lariat ER
I think it’s completely fair to prefer one over the other. I just don’t like when incorrect assumptions are shared and presented as fact and some of the reasons people do not like 1PD I believe are untrue.
I just prefer 1PD, my Model 3 didn’t have it when I first got it and when it came in an update I was ecstatic. Honestly, one of the reasons I like it so much is that it makes trail braking even easier so that I can adjust speed and shift weight from the front to the back of the truck as I want to through a corner without even touching my brakes.
CavRider
Somewhere near Minneapolis
F-150 Lightning, BMW i4 e40, Kia EV9, Ford Expedition
Ahhh, but what you would REALLY like is a switch to be able to apply it to the rear motor only at will eh? ;)
Madasahatter1138
Vancouver Island BC
Ford Transit
Electronics Tech
1 pedal is superior except for the snow.
I have had my truck now for almost 2 years and tried 1PD many times and just couldn't get used to it. We recently got a big dump of wet heavy snow, and I used 1PD again as it allowed the truck to literally crawl down a very steep hill under full control with ease. I was the only vehicle able to get down this hill and bystanders were watching with surprise. I tried it without 1PD on the other side and I couldn't keep the truck slow enough with brakes without ABS kicking in and making me slide a bit, while stressing my passenger out. I drove the next few days in better conditions and will keep 1PD, cant go back!
Also our other EV is my SOs Mini Cooper SE and it's 1PD is very similar, so she had no problem adapting.
WaterboyNorCal
Erik
NorCal
2023 Ford Lightning XLT SR
Nunya business ;)
Yes. It’s like we became Reddit. To each their own. Sometimes I use 1PD, such as when I am descending some steep winding grades in the nearby mountains. I find it easier than using Sport Mode because the max regen means that I don’t have to constantly switch between the accelerator and brake pedals. Same if I am driving in heavy traffic. But for normal driving? I prefer Sport mode with 2PD. Just feels like the best balance of regen braking and still feels similar to a diesel truck and not a golf cart.
I am just glad that we have OPTIONS. It would be great if we could dial in the regen settings ourselves with a custom setting, but I am not holding my breath for that one.
TheDuck
Charles Harris
2024 F150 Lightning Flash
Because my SO doesn't like it. If I turn it on, then she has to turn it off. LOL. On the other hand, when using BC, I like to push the envelope and speed up a bit when it backs off due to a car in my lane. If 1PD is on, as soon as you then release, you start to decelerate. Minor annoyance, i know
Same with mine. I like it. she doesn't.
RickKeen
Minnesota
F150L SR Pro
sw engineering manager,
I did not know about the brakes working with the regen.
THIS ^^
On the Lightning (I believe also on the MME), the brake pedal applies regen and seamlessly transitions to friction brakes when regen braking capacity is exceeded.
So there is NO penalty for using 2 pedal mode in the Lightning UNLESS you frequently brake too hard and get into the friction brakes. The Brake Coach meter teaches you how to stay in the regen zone.
With 1 pedal mode, the brake pedal still works the same, but instead of coasting when you let off the accelerator, it applies regen (but never the friction brakes from the accelerator pedal). So you can drive and slow down with no need to worry that you are braking too hard. On the other hand, its tiring to hold your foot just so when you want to coast, easy to inadvertently slow too quickly, and if you NEED more brakes, you may find out too late and have to quickly move your foot over to the brake pedal.
Other EVs work differently!
In Teslas, the brake pedal ONLY applies friction brakes. To get regen in a Tesla, you let off the accelerator. There is no "2-pedal mode" or coasting in a Tesla. You can adjust the ratio of how much the Tesla regens as you release the accelerator pedal but you cannot get regen from the Brake pedal. Same for the Rivian I test drove. I suspect its the same for most other EVs. Ford is the only one I have confirmed has blended Regen and Friction braking on the Brake pedal.
Timeless Epoch
Chad
2024 F150 Lightning Platinum
THIS ^^
For the reasons you articulated, I stick with the additional control of 2 pedal driving. 1 pedal seems to be a quick fix for regen management that Ford figured out.
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
Talking Hybrid's here, have had two Toyota Hybrids - H400 Lexus & Camry & both would regen with change in accelerator & also application of brakes. Ala Ford, smooth transfer from regen to brake on the Lexus, a bit more of a ragged disconnect in the Camry. Except for highway driving I use Sport mode for the regen, which is pretty non-existent in Normal mode.
RickKeen
Minnesota
F150L SR Pro
I was thinking of pure EVs.
Yes, there are many hybrids with blended regen/braking on the brake pedal.
John Becker
Cincinnati
2023 F150 Light'g Lariat SR, '18 Audi S5 Cabriolet
After doing extensive research and awaiting delivery of my Lightning, I had fully planned on driving 1 PD exclusively. I didn't like it and had trouble adapting to it.
So, I went back to 2 PD. No problem. But after several months, I decided to give 1 PD a try again.
I also tried the various "Normal" and "Sport" modes in 2 PD and 1 PD.
Now, I exclusively use 1 PD in Sport mode. I've learned to feather the accelerator and take full advantage of maximum regen.
I've also found that I've had no problem adjusting when I drive ICE. All is well.
