Status
Not open for further replies.
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
Made it a couple of weeks with a fully updated fully functional Job1 Platinum Powerboost. And it's been such a pleasure to drive too!
Was sitting at the computer handling some emails and out of curiosity logged into FDRS.
A fresh Driver's Front Seat module update available. I don't even know if I want to go through the effort. Lol
Funny how time has changed once the mountain has been climbed once.
Now if it was the PCM or APIM I'd probably go straight to the barn and plug in. :)
I did the seat today. Painless. About 5 mins. Have no idea what it did. Can’t tell if anything.
DeltaDeuce
Dallas, Texas
21 F150 Platinum Powerboost 701A High
Did the same, went to go see if I had a trailer brake update due to the recall and found the driver seat module appear. Did that and all is the same, now if I could just find the trailer brake update...
CUL8ER
Okotoks Alberta
2021 Ford F150 Lariat
I have the same problems: kick switch and approach. I actual prefer for the lights to come on as I approach.. but the boards stay folded until I open the door. If I am working in the vicinity of my truck the stupid boards used to flop out every time I passed by.
But I do use the kick switch and would like to re-enable that.
Got it figured out. There was a DSM SW update today so I did that and it fixed everything. So with the DSM update it put the boards back to factory original settings but instead of the annoying locking the truck from the door outside button the steps going up and not even 2 seconds later they come back down, it appears Ford fixed the bars and they stay up when pressing the outside door button, door outside keypad lock, or fob lock button is pushed and you around the vehicle walking away. This is nice that's finally fixed as that was annoying.
Now before I did the DSM update I was doing some testing in Forscan and found a great setting with the step bars only coming down when the door was opened but as you approach they stay up and your approach lighting still works (as long as you don't have Lincoln AutoFold Mirrors set instead of the original AutoFold Mirrors) as well as the step bar switches will work. This is great when you are walking around your vehicle but tired of the steps going up and down constantly. My settings on the sync screen are Power Running Boards Auto, Timer 5 min, Approach Setting and Lighting set to on. After you have this all set leave it and don't touch. Make the changes below in Forscan then do the module reset and away you go. So the settings I used were the following.
744-23-01 > 0001-0001-00XX
744-23-02 > 0101-0000-XX
or for those with older block setup for that line 744-23-02 > 0101-00XX
Mike G
N. AL, USA
2022 F-150 Lightning, 2023(J1) Mach-E GT-PE, '24 Bronco Heritage 2Dr
Can someone check to see if I have any updates VIN 1FTEW1E86MFC76534
I believe I have a GWM update still but it's showing I have no updates available
Doesn't show you have any updates for DL.
Ruffiano99
Joe
NY
2021 f150
Any ideas on what this means?
got past this, figured out i needed to click the little redownload button in FDRS.
… but then kept getting stopped at this…any ideas? Looks the the APIM. Tried resetting the module a bunch of times already.
Ford F-150 Lightning ECU module programming guide using FDRS F363FFE5-FBC2-4D39-BA08-25D05192778D
Shoebox72069
MN
2021 F150 Powerboost Lariat
Has anyone been able to flash the BECM?
Anytime I've tried to flash this it immediately comes back with
Procedure Unsuccessful - GetVechicleNodeInfo.
This thread doesnt have too much on this particuar module compared to all the others.. Should be caught up on everything else!
Shoebox72069
MN
It's going to be a leap of faith no matter what. I don't see any meaningful way of really protecting yourself if you send yours out. It's an honor system. You could require some kind of deposit, but then the borrower is taking a leap of faith that they will actually receive the Mongoose and their deposit will be returned after they send it back. Only sending to established members of the forum would help somewhat, but obviously no guarantees.
I am definitely interested in doing some kind of loan "program" if anyone is willing. I am new on this forum but am well established on the F150 forum under the same Brad34 name.
Where in MN are you? I'm in the South Metro and have a Mongoose + VCX
Ebrou
Mobile, AL
2021 F150 XLT SCREW 5.0L Sport 4x4
the post just above by: @Ruffiano99 he said "got past this, figured out i needed to click the little redownload button in FDRS."
Ruffiano99 said:
Ford F-150 Lightning ECU module programming guide using FDRS 064c668d-4af2-4ccb-b396-0ab30f5c8cf8-jpe
Shoebox72069
MN
got past this, figured out i needed to click the little re download button in FDRS.
It doesn't say the exact module, and I've tried the re download with no success.
The second part says... "Unknown Error".
jmm3807
Phoenix AZ
www.seasavvyaquarium.com
2021 F-150 Platinum 4x4
Business Owner
Did the driver side module this morning. This APIM update was available but haven’t started. Maybe later today or this afternoon. I was updated all the way through BC and this is the first day this has popped up.
Ford F-150 Lightning ECU module programming guide using FDRS 0DA94692-43B5-4E6D-BBA7-EBE8575F34F7
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
I was. But I really can’t tell you anything about it. It showed up with other updates and I installed it. It was a non-event.
Ajzride
Alan
Houston
Eng
@Ruffiano99 , @Shoebox72069
Those odd errors have been fixed in the past by reinstalling FDRS. If you go that route, be sure to release your license before you uninstall so that it is is available again after you get done.
Status
