Avocadodude
- First Name
- Kurt
- Feb 24, 2022
- Fallbrook, CA
- F150 Lariat
No, but we want to! ???You guys dont believe that do you?
Still showing 5/23. No sticker.
I was able to locate my sticker finally by going through the windowsticker.ford direct.com site and using the order code that my dealer provided when it was placed.Thanks for the update guys, hopefully they get your stickers generated soon!
I have the same blend date and noticed that the sequence for @LSP’s truck is 6/200 while mine is 321/470. My sticker was issued on May 11 and when I looked this evening, there were no changes. What is going on? I’m confused!!I was able to locate my sticker finally by going through the windowsticker.ford direct.com site and using the order code that my dealer provided when it was placed.![]()
LSP's truck has the spray-in bedliner. As discussed elsewhere, that option uses different sequence numbers.I have the same blend date and noticed that the sequence for @LSP’s truck is 6/200 while mine is 321/470. My sticker was issued on May 11 and when I looked this evening, there were no changes. What is going on? I’m confused!!
Duh. And of course, I have no options. Just a “base“ Lariat ER (which we really can’t call base since it is extremely well equipped).LSP's truck has the spray-in bedliner. As discussed elsewhere, that option uses different sequence numbers.
Im 5/25 blendHere is how the 5/23 build week data stands, if anyone needs to move, let me know in this thread, if if you have an update still pending with the official forum table, let me know here as well.
How do you know what my blend date is? I haven’t seen anything with that info yet.Here is how the 5/23 build week data stands, if anyone needs to move, let me know in this thread, if if you have an update still pending with the official forum table, let me know here as well.
Were you ever able to get your window sticker? The blend date and sequence number are at the very top of it..How do you know what my blend date is? I haven’t seen anything with that info yet.
So I'm surprised you aren't capturing the sequencing number - we need to know which trucks are going down the assembly line behind each other!!! OK - I jest and kid, but it is fun and interesting. Back in post #83 noted that @Oneand0's truck and mine are going down the assembly line literally just a couple apart.Here is how the 5/23 build week data stands, if anyone needs to move, let me know in this thread, if if you have an update still pending with the official forum table, let me know here as well.
