Initial range after charge well below advertised range- 2025 Flash
user-name-required
T
BC
2024 F150 Lightning Flash, 2023 ID4 pro S
For my $0.02...
Early April I was driving around the greater Vancouver and Frsaer Valley area, all the way up to Squamish. Decently sunny spring weather.
I did 107km of driving on the highways (but highways with traffic, and then a twisty roller coaster highway, so averaged probably 80kmh or 50mph), and I got 27kwh/100km. With a 131 usable battery, this is an implied range of 485km, or about 95% of the EPA estimated 510km range.
So yea, the truck can and will get its efficiency rating. But if you are driving at 60-70mph or more, at constant speed without any slowing down for corners, traffic, etc., yes in my experience 400km (or about 250 miles) is probably accurate.
AND....my Guess-o-meter on the instrument cluster still shows an implied range of 400kms when full. Even though I know that it can do more.
22legit2quit
2024 Ford Lightning Flash ER
Keep your foot out of it and off the highway and you’ll see the range. On the highway you’ll lose 10-20% with wind and whatever your speed is. Get the charging adapter for the Tesla superchargers and you’ll be fine.
TrojanThor
2025 F150 Lightning Flash, Genesis GV60 Advanced
38 one way commute in Texas Hill Country 5x/week. 2.9 mi kwh possible when not using AC, driving speed limit (under 55 most of the way), 1 pedal Normal or Cruise control 70%. 25' Flash Build 1 133kwh
Ford F-150 Lightning Initial range after charge well below advertised range- 2025 Flash 20251121_184922
22legit2quit
Gotta use that sport mode. Always seems to get me 5-10% extra range over the entire charge and the regen braking/one pedal engages with quite a bit more speed and intensity.
jamelski
Sacramento
2024 Lariat
You got the standard range battery on your flash on accident I’d call ford BEV team get a ticket going and apt to get it fixed. It happens.
Traconesu
Patrick
Quad cities, Illinois
Ford lightning platinum
Wow. I'd like to see more lightning readings like this.
25.8571 MPH, was the truck idling for an extended period?
taraafico
ali
f150 Lightning
self
In a 70-80 degree temperatures with soc of 100% you should have gotten at least the advertised mileage, but in a colder weather is different.Batteries simply don’t like the cold.
ZeusDriver
East Coast, USA
2022 Lightning
If you want to know what you should be getting, reset one of your Trip logs (I use Trip 1) and drive for a week. Take the efficiency number (miles per kWh) after your week of typical driving and multiply it by 131. That's your typical driving range for the weather/terrain.
If you average 2.0mpk, that's ~260 miles. You need 2.4ish to achieve the EPA rating.
I just wanted to support this. The reported energy usage is accurate, not a guess, so if you drive around at a leisurely pace, you will probably find that you can get 2.4 or 2.5 miles per kWh. If you repeat that a few times, you should get a better indication from the GOM. If you are still getting low range, but are generally driving at 2.4, then you should have the battery checked.
