Leveling spacers same between Lightning and ICE?
WXman
Central Kentucky
www.facebook.com
2025 F-150 Lightning Flash
Meteorology/Transportation
I'm going to order a leveling kit for the front of my Lightning tonight. And searching the listings for the specific one that I'm interested in it shows that it fits all of the ICE versions of the F-150 excluding the Raptor. It says nothing about whether or not it will fit the Lightning. Are the front struts the same? Can I use an ICE leveling spacer kit on a Lightning truck?
AZT9
Peoria, AZ
I can confirm they are the same. I can also confirm that they will wear out your UCAs pretty quick. Cost more but the Eibach kit is well worth it For a 3” lift up front
WXman
WXman
Central Kentucky
www.facebook.com
Thanks. I bought the MotoFab 1.5" leveling spacers for $65 bucks. I typically use eBay spacers for around $25 bucks because it's a block of aluminum. How can you screw that up? But in this case I splurged for the MotoFab since this is such an expensive truck. LOL.
My struts and coils have 1000 miles on them. No sense in trashing these. I just want a small lift up front. And these top load spacers usually work great. My 2005 F-150 has had spacers like this up front and it's got 225,000 miles now with no issues.
AZT9
Peoria, AZ
That’s pretty mild. You should be good! I put 65k miles on the truck with a 2.5 puck before signs of failure presented themselves
abcut973
Anthony
Denham Springs
Donyou mind sharing the signs you saw?
AZT9
Peoria, AZ
Didn’t notice much while
Driving. Noticed it when rotating the tires. There was noticeable play on the spindle when swapping tires. Upon replacing the UCAs, it was obvious that the factory ball joint was done. Very loose
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
Do not do spacers. The ride will suck, your alignment will always be out of spec, drive path will drift, and suspension components wear out quicker.
If you're going to do a front level, get a quality made kit like Eibach or Fox struts with longer UCAs.
Do not go cheap on this. You will regret it. Trust me.
CLUBSFIT
Tony
24 Lightning Platinum
Ford dealer manager
Here I will help... YES they are the same. Just get it aligned after and don't go over 2" with just blocks.
WXman
WXman
Central Kentucky
www.facebook.com
I've lost track of how many trucks and SUVs I've put these types of spacers on. A dozen? Twenty? Never had a single issue. And as I already mentioned, I have a 2005 F-150 right now with 225,000 miles on it and it's had 2.5" spacers on top of the struts for the last 15 years.
I've also gone the replacement strut direction on a couple of trucks, mainly using Bilstein parts. Wasn't a fan. Changes the ride quality more, and you never know exactly how much lift you're going to end up with.
csukoh78
Nope
SE USA
Happy for you. Nevertheless I remain correct in everything I've said.
WXman
WXman
Central Kentucky
www.facebook.com
So another question....
For those of you who have installed your leveling kits yourself, did you have to remove the frunk to make access to the top 3 nuts on the struts?
digitaldad
ABQ
2023 Lightning Lariat ER
Not installed myself, but I removed my frunk tub when taking to get my lift installed and showed the installers. With that said, I'm not sure if they used that access or not.
On a few of the videos I've seen, they have not taken the tub out and tools reach easily underneath (and in).
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
Taking the tub out is super easy, worth it just to have a look what’s underneath.
RLXXI
S. E. Louisiana
Auto tech
I kept telling my self and others the first thing I was going to do was yank that tub just to get an eye full, I'm a tinkerer by birth, career, hobby.
3 months later still haven't done it lol.
