Make the truck shut up already
neririn
Usa
F150 MachE
Anyone who owns a Ford knows how much they LOVE their chimes.
If there was a MotorTrend 'Annoying sounds constantly played at high volume' award Ford would be the reigning "back-to-back-to-no other company has actually come close to beating them in the history of the award" champion.
So yeah, any idea how to make it stop? I got a power up update today where Ford was proud to announce a LOUDER chime. Really? LOUDER?
Who on God's green earth thought ANY chime needed to be there at all, let alone louder!?
If I sell this truck it will only be for my sanity.
Try reading what it says. It is the chime when the frunk is not properly closed. In normal use, you will never hear it.
MRButtler
Matt
2022 Lariat Lightning
My dash doesn't say "Active Air Dam" anymore, but I know it's munched a few birds.
Amps
Mid-Atlantic
Bolt
Fewer annoying chimes. Stolen from another poster here:
Switching the Seatbelt Reminder On and Off
WARNING WARNING: While the system allows you to deactivate it, this system is designed to improve your chances of being safely belted and surviving an accident. We recommend you leave the system activated for yourself and others who may use the vehicle.
Note: The driver and front passenger warnings switch off independently. When you perform this procedure for one seating position, do not buckle the other position as this cancels the process.
Note: If you are using MyKey, you cannot disable the seatbelt reminder. Also, if the seatbelt reminder has been previously disabled, it will be re-enabled during the use of MyKey.
Read Steps 1 - 4 before proceeding with the programming procedure.
Make sure that:
The parking brake is set.
The transmission is in park (P).
The ignition is off.
The driver and front passenger seatbelts are unfastened.
Switch the ignition on.Do not start the engine.
Wait about one minute until the seatbelt warning light switches off. After Step 2, wait an additional five seconds before proceeding with Step 3. Once you start Step 3, you must complete the procedure within 30 seconds.
For the seating position you are switching off, buckle then unbuckle the seatbelt three times at a moderate speed, ending in the unbuckled state. After Step 3, the seatbelt warning light switches on.
When the seatbelt warning light is on, buckle then unbuckle the seatbelt. After Step 4, the seatbelt warning light flashes for confirmation.
This switches the feature off for that seating position if it is currently on.
This switches the feature on for that seating position if it is currently off.
neririn
Usa
F150 MachE
I have read it. Does the frunk just randomly come open while driving?
If not, how/why am I going to need an alarm while driving. If so, FIX THAT. Frunk should not open while driving. Heck, it won't even continue to close while in drive, why would it be allowed to open?
Chimes are not a fix. :).
I do realize how first world a problem this is, I am simply looking for a way to have less chimes not more.
Frunk closes, but isn't properly latched. Moron drives 80mph and frunk flies open. "I didn't hear the chimes" he says.
This is not the sound it makes when opening or closing.
neririn
Usa
F150 MachE
Yellow Buddy
Mid-Atlantic
Smart Ass
Better louder than adding in additional chimes….or is that the next update?
lakeguy55
New Hampshire
2023 Lightning Lariat, 2011 F-150, 98 Expedition
Was driving mine for only the 3rd time yesterday. All of a sudden a chime at full volume almost made me go off the road. Then a few more. No obvious indication on either screen what it was for. Later, after stopping, finally figured out it was telling me that I got some texts. Then spent the next half hour searching here, Google, etc. to try to figure out how to turn it down or off. One of those ones that there are about 10 different suggested ways out there. Took a while to find the one that worked for me.
chopedogg
Ari
Colorado
I'd simply like to be able to disable the beeping sound when opening/closing the Frunk...anyone know if that's an option? I couldn't find it.
You do realize that this was your phone, connected to the truck, making the noise, because you connected it, right? The truck did nothing on its own...
Anytime the truck makes a noise, turn the volume down while it is making the noise. This applies to things like Google Assistant, phone noises, etc. Truck chimes cannot be turned down.
