My new EVSE setup. The Tesla Universal Wall Connector is fantastic device.
flyct
Jerry
South Florida
Blissfully Retired
When only one is charging i only get about 10.6 kw, not the 11.
When charging my Lightning myTesla wall connector reports 11.7 KW output on the Tesla App and the Ford pass app reports about 10.6 kW. The difference is the Tesla reports the actual output and the Ford reports charge accepted by the Ford battery after efficiency losses. Typical loss ranges between 5% yo 10%.
My most recent charge history on 2/1/25
Tesla app reported 25.4 kWh delivered
The Ford app reported 23 kWh added.
Prior charge session 1/31/25
61 kWh on Tesla app
56 kWh on Ford Pass app
flyct
Jerry
South Florida
Blissfully Retired
13 years ago, when I installed my first EVSE, I went with a level 2 Schneider Electric EVLink, good for 30 amps/7.2 kWh.
It served me well for the 3.6 kWh PHEV’s I progressed through, and held its own charging my Tesla MY, at 7.2 kWh, with a NACS adaptor.
Early last year I gave into the desire for a full 48Amps/11.5 kWh to take full advantage of the Tesla’s charge rate capability.
This time I went with the Tesla Gen3 Wall Connector. Beautiful piece, and works like a charm.
Last fall I of course got my beautiful F150 Lightning. Been charging both EV’s with the single Wall Connector, and now a J1772 adaptor for the Lightning. It all worked well, but was a slight coordination PITA.
I’d been wanting to do a second EVSE install, but that would typically require an additional circuit with associated breaker, wiring and drywall surgery or conduit runs back to the panel.
Also a PITA.
Well, not anymore …
Tesla recently introduced their new Universal Wall Connector. It’s pretty awesome. It has a J1772 adaptor built into the housing, that allows you to easily alternate between NACS and J1772. Nice.
But what really makes it special is a new design that allow more than one Wall Connector to literally daisy-chain off the next, and PowerShare the load.
This means a super easy install of multiple EVSE’s on a single existing circuit, load sharing coordination between the two via internal WiFi.
24 inches of wiring is all that’s required.
It also allows DC direct back feeding to the house, with the proper vehicle and home integration equipment.
Very nice design and versatile.
Pics to follow….
Greg,
Thanks for posting this. I think you just cost me $550. ?
Our EV history is similar to yours. Original Schneider L2 30 amp/7.2 kw output installed 10 years ago to charge Nissan Leafs. The Schneider was replaced with a Tesla Wall Connector wired to a 60 amp circuit 2 years ago when we got first Tesla.
Now we have 2 Tesla Model Ys and a Ford Lightning. At our house the Tesla Wall connector charges all 3 only one at a time. As simple as power sharing is I’ll likely buy a Universal Wall connector and install it in the existing location and run wires from it and relocate the original gen 3 Wall Connector.
The load sharing ability that the Universal Wall Connector has with an input and output connection eliminates complexity of needing a sub panel to split the power to each device. I can install them side by side with minimal expense. Then I have ability to charge any combination of 2 of our 3 EVs at once. I like it!!
The Tesla Universal Wall Connector was introduced 18 months ago.
HOTAS
HOTAS
ā€˜24 Lightning Flash, Tesla MY, Chevy Volt, PiPrius
Airbus Pilot
Also a PITA.
Well, not anymore …
Pics to follow….
so, here’s the install. Universal Wall Connector on the right, Gen 3 Wall Connector on the left. Universal has wiring pass thru for daisy chain connection. Works perfect. The built-in NACS/J1772 adaptor is really nice. Just un-holster the one you need.
The conduit change (for the truly observant) was because the first elbows were so close they wouldn’t allow the unit faceplate back on. Didn’t see that coming. Lol.
Ford F-150 Lightning My new EVSE setup.  The Tesla Universal Wall Connector is fantastic device. IMG_7115
Ford F-150 Lightning My new EVSE setup.  The Tesla Universal Wall Connector is fantastic device. IMG_7116
Ford F-150 Lightning My new EVSE setup.  The Tesla Universal Wall Connector is fantastic device. IMG_7118
broncoaz
Cape Cod, MA
Looks good. Theoretically it’d be very straight forward to swap my Gen 3 for a Universal and add the necessary conduit to install the Gen 3 on the other side of the garage door. The conduit run would be about 20’.
HOTAS
HOTAS
Airbus Pilot
Exactly what I did. The new Universal unit literally used the previous existing mounting holes from the Gen 3 baseplate.
Super easy addition, with PVC conduit, although not quite as elegant looking.
Took a couple trys to set up power sharing feature via the install app.
The key is to disconnect phone from home WiFi and disable home WiFi auto connect. Then scan the Universal ā€œleaderā€ QR codes, making a connection with the units to update software, make setting for sharing and then scan the QR code for the follower and update its software if applicable. Then unit setup is finished.
Reconnect your phone to your home WiFi.
At that point you can connect them to your home WIFI in the Tesla app, for data monitoring and remote control. Or not.
If you don’t connect them to your home WIFI, just let them be unmonitored stand alone power sharing charger units.
Oh yeah, Tesla does want pics of install uploaded to them during the setup process. No big deal. I uploaded really basic pics.
May be a way to get around that, IDK.
electricpig
Tim
Northwest Arkansas
23 F150 Lightning XLT, Tesla Y
Thanks for this. I had planned to do the shared setup, but could never find clear instructions that the electrician would accept. Side note, it's my understanding that a universal wall connector is not required, that two version 3 are fine. My understanding (possible incorrect) is the universe units internals are the same, just has the adapter.
flyct
Jerry
South Florida
Blissfully Retired
YES, Sort of!!
The base mounting plates are different an not interchangeable.
The Version 3 only one possible connection to land each wire input
The Universal has 2 available connections to land two wires per input. This makes "daily chaining" them easy.
YES you can configure 2 or more versions 3's BUt you can't easily daisy chain them. You would need a junction box or a sub panel to split each line to two or more inputs, depending on how many Wall Connector's you want to power share.
See pictures below.
Ford F-150 Lightning My new EVSE setup.  The Tesla Universal Wall Connector is fantastic device. Universal
Ford F-150 Lightning My new EVSE setup.  The Tesla Universal Wall Connector is fantastic device. Gen3
Ford F-150 Lightning My new EVSE setup.  The Tesla Universal Wall Connector is fantastic device. Gen 3 Wall Connector Manual
flyct
Jerry
South Florida
Blissfully Retired
@HOTAS
I sent to a PM with a technical question.
electricpig
Tim
Northwest Arkansas
YES, Sort of!!
See pictures below.
Thank you.
Sullyfamily
Tx
None
Also a PITA.
Well, not anymore …
Pics to follow….
I have been thinking of purchasing the Tesla Universal charger. Can the included adapter be used at Tesla super charge stations or do you still need another adapter?
flyct
Jerry
South Florida
Blissfully Retired
Included Adapter CAN NOT be used as a Supercharge station. You will need a Fast Charge adapter for supercharger.
PJnc284
Garner, NC
Finally bit the bullet and bought/installed one a couple weeks ago. I put the Charge Station Pro at my parents and had been using the FMC on 120v at home for about a year. That 10kW sure is nice compared to 1kW. :cwl: Maybe just me, but the app leaves a lot to be desired and the fact that you need the separate Tesla One app to update certain configuration after initial install is just annoying.
flyct
Jerry
South Florida
Blissfully Retired
I’ve had a Wall Connector for almost 2 years. Other than initial installation setup, Iā€˜ve never needed to change the configuration.
from anywhere, as long as you have cellular or internet connection
1- you can change access control with the Tesla app remotely
2- you can monitor charge rate
3- you can see how much kWhs the truck took
4- you can view charge history
5- you can change your utility rate to accurately see what it costs.
5- If you are charging a Tesla you can manage (limit) charge rate in the car screen I wish you could do this with a Ford.
I had a user created error with intermittent charging and I called Tesla support. They remotely logged into my wall Connector and diagnosed the fault. I had inadvertently set non-charging times.
These have been bullet proof. I have one at home and one at my cabin. The ones I have are not the Universal version. I’m going to buy a Universal version and use it to create power sharing 2 Wall Connectors since I have 3 EVs.
PJnc284
Garner, NC
My issue was that I realized that liquid tight is 60C rated wet after installation so I was going to bump the charge rate down to 40 amps in case the inspector balked as I have it installed outdoors. Kinda moot since the inspector didn't say anything but the only way to adjust the amperage is with the Tesla One app which also requires you to hold the button on the nacs handle similar to initial configuration which is a bit annoying in and of itself. At least with the FCSP, everything can be managed from the FordPass app even if you have to do a song and dance, flip the breaker and pray if you happen to want to adjust the amperage for one reason or another.
The charging stats made me scratch my head as well. Under Energy, I assumed it was showing what was actually delivered to the battery since it seemed to align with the FordPass app and that the numbers under Charge History/View Charge Sessions showed how much the UWC supplied before losses since it was always 1-2kWh higher but they were both the same for one of the charge sessions.
Ford PassTesla Charge HistoryTesla Energy
9-Feb​
2121.920.8
15-Feb​
1617.115.9
16-Feb​
2021.321.3
18-Feb​
5154.453.5
