Suddenly charging at 3.3kw and not at 9.6kw
Baja Lightning
Willie
2025 Lightning Flash, 2020 F350 6.7L Rolling Coal
I plug in almost every day to our Ford Charger, but today I am only charging at 3.3kw (16a) as opposed to the normal rate of 9.6kw.
What can be the problem?
Is it a Ford / truck issue?
Charge rate is set to 48a,
K6CCC
Glendora, Calif.
Two Way radio systems
Make sure the FCSP firmware is up to date. There was a firmware version a while ago that had that exact symptom. I had it happen once. Updated firmware and that cleared the problem. Other people have reported the same thing.
Though your charger is set to 48a, and assuming it's a FCSP, there is a 'software' setting in Fordpass, that can be corrupted, or stuck at a lower than optimum rate.
You can find this under the Energy tab> Charge Station> Settings> Max Charge Current> Edit> slider to the right most available level> Save
You may need to repeat the adjustment a couple times and power cycle the EVSE by turning the circuit breaker feeding it OFF > ON to make the change stick.
If that does not work. test the trucks ability to charge on Level 2 equipment at a public charging station to see if you get better performance, take note that some of these units are also limited in amperage.
S. E. Louisiana
Auto tech
I would cut power to the charger via the breaker to give it a reboot then measure again.
Baja Lightning
Baja Lightning
Willie
Tried that se real times….
S. E. Louisiana
Auto tech
Assuming you've tried what others suggested above, time to call an electrician. Need to make sure you're getting both legs of 120v for 240v total to the charger.
Check the truck for DTCs. There could be an issue in the truck that’s causing the issue.
