- First Name
- William
- Jan 8, 2022
- rural Georgia
- 22 LIGHTNING PRO IcedBlueSilver 8/23/2022
- Occupation
- Owner
1)Tow/haul mode shuts off one pedal drive.
I love the one pedal drive once I got used to it. It seems silly to not use the Regen function with a load? If you have a trailer connected with in regular mode the blis system keeps thinking someone is in the Blindspot.
First, the truck ALWAYS uses regen, no matter what 'mode' you are in, but in 'Sport' or 'Tow' mode you will always get MORE regen. One Pedal drive feature has nothing to do with regen, it simply is applying the physical braking, for you, to bring the vehicle to a complete stop.
Secondly, there is nothing that says that you 'must' use TOW mode when towing. It's simply another option - you may choose to use 'Normal' mode, or 'Sport' mode, if you wish, because you like the outcome better. I imagine that the engineers did not apply one-pedal to towing simply because you are then asking the truck to bring the full vehicle AND trailer/camper to a complete stop - that could result in undesired outcomes, with all the added weight.
2) My truck doesn't save my trailer as default trailer. Have to set it up each time I connect it. Wish you could program the default settings different.
Interesting, as I've never had this issue. The 'default' camper I originally set up always comes as the 'option' when attached to it.
3) How tall the truck sits and how it sits butt high. I'm waiting for the aftermarket to offer a lowering kit to at least make the truck sit level without lifting it. Even with 600lbs of tongue weight it sits 4 inches high in the back. Me personally I would lower it 6-8 inches and do away with the running boards. The bed sides are so tall as it is you can't get stuff in and out without using the tailgate.
TRUE: and I believe most of this is due to the need to keep the battery pack well above the road surface. At approximately 8" or so now, it's likely the engineers did not want to push the truck lower, although being able to 'reach over' into the bed might be nice, at times. I personally see no issue with it - it's a truck.
4) folding shifter. To me this seams like unnecessary parts. Why not make it push button on the dash somewhere and just give us either another seat up front or a useable flat area in between? Currently you have to move all your stuff including drinks in the cupholder, fold the shifter ECT and then fold it all up to get in the console. I ended up building a wooden platform to hold my paperwork and clip board. Maybe I'm old-school and just got used to my F250 being more user friendly?
I suppose that some of us 'like' the shifter, whether folding or not, and some will not. I've had a Nissan Leaf, and now my wife's Kia Sorento PHEV, and both have the rotating knob. I've grown accustomed to both options, and don't mind either. Now, whether the 'folding' shifter is a 'neat' feature, or a relatively unused feature, is up for your own desires. I like the shifter, as it comes across as the more typical 'truck' style, but I also don't mind a knob that accomplishes the same task. For those of us with a PRO, the folding shifter is certainly just a 'feature', that's mostly nothing more than an unused 'idea'. If it's a hold-over from other ICE F150s, I could understand. If it's a 'new' feature, then it was more of an afterthought.
5) integrate the existing cameras to allow recording. It's kinda silly with all the tech that comes on this truck to not be able to replay the info from the cameras.
I guess most truck owners would wonder why you'd ever want to 'replay' anything from cameras.
6)I understand this is a safety issue but I don't like how you can't move the truck with the door open. I never new this was an issue till I got the lightning. Occasionally I will have to readjust the truck on a job site or such and it's awkward to get in and completely shut the door to move 1 ft.
You CAN move the truck with the driver door open, once the truck is already moving.
I've done this several times, but I think the safety mechanism is more designed to keep you from putting the truck into 'gear' while the door is open. It it's already moving, then the door opening should not affect it.
I'll test this today to confirm.
I've been driving pick up trucks exclusively for over 35 yrs so maybe I get in a rut? What would you change?
Yes, agreed: we all 'compare' to what we already know, or as used to. If this was a new vehicle for an owner that has not had a 'new' vehicle in many years, the new 'differences' are amazing, and probably much less to be critical about.
over 10,000 miles in 111 days: this truck is AMAZING!
