nanohead
Well, I followed all of Fords recommendations, but was scared silly with range anxiety on Xmas day. It was around 17 degrees in northern NJ. Point of note, we've owned a Mach E for the past year and half and am familiar with some form of cold weather range decay. Also an engineer, and I understand many of the trade-offs the engineers at Ford dealt with to get this truck into production as designed. I also understand this is the first winter with these F150 Lightnings in service, so we are all going to have to figure this out on the fly.
Kept the truck plugged in yesterday morning, couldn't get the "precondition" schedule thing to work, but did 2 cycles of remote start for 15 minutes, and then actually got in and started the truck with it plugged in. It gave me this idiotic Pro Power message, which makes no sense.... It was plugged into the Charge Station Pro and the charger was charging (flashing blue light). While it was plugged in and on, range INCREASED from 302 to 306 miles, presumably as the truck was heating itself, but I have no way of knowing.
We then set out for the family gathering, which was 70 odd miles away. I actually decided to modulate speed, and try to maximize for range on the drive. I stupidly assumed that the GOM saying 306 miles of range should smartly get me through the 140 mile round trip. Wrong
The cabin was warm, we turned down the seats and set heat to 68. There were three of us in the truck. It was cold outside, and while we tried turning the heat off, it got too cold in the cabin.
Range was plunging at DOUBLE the rate it should have during the first leg of the trip, which was 70 miles. Range dropped from 306 to 165, which is a giant miss..... 141 GOM miles consumed for 71 real miles. That is bad... really bad.
We left to return home after around 5 hours, the truck wasn't plugged in, and I did 1 remote start to heat the cabin. During the remote start period, the truck lost another 5 miles and was at 160 when we set off for the 70 mile return trip. At this point, I was pretty terrified we weren't going to make it, and while there is 1 charger on the route, we were time pressed and was hoping we'd just scrape by.
Again, the GOM plunged by way more than actual miles. I had cruise set to 65, seats on 1, cabin heat on 68. By halfway through the trip, I went into white knuckle mode, and became convinced the battery would die hard before I could make the driveway at home. I was somewhat shocked that this $80k+ truck with a published range of 320 Miles could barely make 140 miles. Not good
By the last 1/3rd of the trip, I was cycling 1 pedal drive regen somewhat aggressively on the down hill sections of the southern most part of the NYS thruway, and started to reduce range decay a bit. The short of it is, the 141 mile round trip consumed 232 on the GOM, which is terribly unsatisfying and candidly, just bad.
My basic takeaway is that the truck's range of 320 is not true in general. All the stuff that the Ford EV GM said during the SOC youtube interview about cold weather operation didn't work at all, and that those of us who purchased the Lightnings as a family hauler need to be super cautious this winter to not get stranded.
Choosing between range and freezing inside the cabin, or being basically comfortable inside the cabin and getting stranded is a terrible trade-off. The fact that they deleted my heated steering wheel doesn't help.
This truck is one of the most beautiful vehicles I've owned (out of way more than 100), but if it can't be reliable with some reasonable range, then it might be too early for something this big and heavy to be a practicable EV for family service.
